Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Flat stencils similar to Autocad? |
| Print at Oct 6, 2026, 3:21:02 PM | |
| Posted by amanlikeisaiah at Feb 25, 2024, 9:10:44 PM |
Flat stencils similar to Autocad? Hi, are there any stencils that are simple line drawings similar to what an audocad 2d floor plan would look like? |
| Posted by Puybaret at Feb 27, 2024, 11:36:46 AM |
Re: Flat stencils similar to Autocad? You could use the polyline creation tool which allows also to create curved lines. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by captaincook at Feb 27, 2024, 12:29:29 PM |
Re: Flat stencils similar to Autocad? Bonjour Emmanuel. Je découvre dans votre message ci-dessus l'existence de l'outil de créations de polyligne. Bien qu'utilisant la dernière version 7.2 de Sweet Home, je n'ai que l'outil de création de lignes (rectilignes) mais pas celui de création de polylignes qui semble très pratique. Et je ne sais pas où trouver le plugin pour l'installer. Merci d'avance. |
| Posted by Puybaret at Feb 27, 2024, 1:18:59 PM |
Re: Flat stencils similar to Autocad? Curved line is the last choice in Join style option. Plese read the help about polylines for more details. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by amanlikeisaiah at Feb 27, 2024, 1:33:42 PM |
Re: Flat stencils similar to Autocad? Thanks, I'll give this a shot. How do I make perfect circles? |
| Posted by captaincook at Feb 27, 2024, 1:51:02 PM |
Re: Flat stencils similar to Autocad? Merci Emmanuel. En fait, ça marche à condition de tracer plus d'une ligne d'un coup, ce que je n'avais pas compris. |
| Posted by Puybaret at Feb 27, 2024, 1:57:31 PM |
Re: Flat stencils similar to Autocad? You can build a perfect circle if you join 4 points which form a square. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 6, 2026, 3:21:02 PM |
