Print at Sep 26, 2026, 5:44:10 PM
Posted by dorin at Feb 26, 2024, 7:38:37 PM
Regular room plugin
Regular room version 1.0
In the series of YAUP another useless plugin under a motto:
"Sometimes even simple things are hard to do."
With a little CAD could be more easy.
It could be found under Tools and on tool bar as a pentagon icon.
This plugin generate a regular room between 3 to 30 sides.
You have to input the sides number, the length of the side and the room center position.
It look like this:
Also on Source Forge.
Posted by Keet at Feb 26, 2024, 7:56:53 PM
Re: Regular room plugin
This will make creating my dodecagon shapes a lot easier. Until now I used dodecagon shapes created in Blender as parts for furniture or buildings. In Blender you can set the number of sides for a cylinder similar to your room plugin. This especially makes it easier for me when I need walls/rooms with a specific lenght. YAUsefulP.
Thank you Dorin.
Posted by Vinci68 at Feb 26, 2024, 9:32:41 PM
Thanks a lot Dorin, one more step to the realization of furniture and objects with SH3D... I'm using Sketchup less and less and I'm now making a lot of things directly in SH3D!
Posted by Keet at Mar 6, 2024, 9:18:48 AM
Could you up the max # sides to 32? (2,4,8,16,32)
By-the-way, why not 64 or 128?
Thank you!
Posted by dorin at Mar 6, 2024, 6:12:48 PM
News in version 1.1
-add Chinese translation thanks to YGYL
-increase sides max number to 300 (hope it is enough even for Keet smile ).
Also on Source Forge .
Posted by Keet at Mar 6, 2024, 7:29:03 PM
Thank you, I think that is enough laughing With 300 sides it might even be smoother than a cylinder.
(The plugin manager seems to have a little bug regression: the "Plugin installed ...Ok" close window hides behind the main window again.)
