Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 7.3 |
| Print at Sep 23, 2026, 12:34:34 PM |
| Posted by Keet at Apr 2, 2024, 8:18:39 AM |
Re: Sweet Home 3D 7.3 Do I understand it right: Originally when you imported furniture the object had to be in a category. This landed a lot of furniture in the Bathroom category because that was the first in the list.Before 7.2 it was not checked by default but in some earlier versions. In 7.2 it was checked by default. In 7.3 it is not checked by default. I think it was in version 7.02 that a checkbox 'Add to catalog' was added which lets you choose whether or not to add your import to a category. Unchecked the imported object was not added to the catalog. In 7.2 The User category was introduced as a default category. With the checkbox 'Add to catalog' unchecked imports were still added to the catelog in the User category. With the checkbox unchecked the import should not have been added to the catalog at all. In the latest 7.3 beta-1 this is solved so that when 'Add to catalog' is uncheked the import is not added to the catlog. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Keet at Apr 2, 2024, 10:03:20 AM |
Re: Sweet Home 3D 7.3 - The program won't hang anymore when deformation groups are missing in a 3D model file. That does work correctly now. (hurray!)Important: The same import should be implemented for import in the next version of the Furniture Library Editor. The editor doesn't hang when you try to import, it just refuses the import completely. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Apr 2, 2024, 10:33:19 AM |
Re: Sweet Home 3D 7.3 Thanks for your tests and feedback The regression in the furniture import wizard of the version 7.2 is that a 3D model imported in the plan is added to the catalog even if you keep the checkbox Add to catalog unselected. You have to select then unselect the checkbox again to prevent the imported model to appear in the catalog. As explained in the help, importing a 3D model into furniture catalog or into home depends on whether the catalog has focus or not when you choose Furniture > Import furniture... menu item. If the furniture list, the home plan or the 3D view has focus when you choose this menu, the imported model will appear in catalog only if you check the Add to catalog check box, at the third step of furniture import wizard. The same thing happens if you drop the file of a 3D model onto the furniture catalog or the plan. When you select a single object in the 3D view the keyboard combo ctrl+E works to get the modify dialog but not if you select multiple objects in the 3Dview. I just tried under Windows, macOS and Linux, but didn't notice this issue. It would be astonishing that a plug-in could alter this behavior.The same import should be implemented for import in the next version of the Furniture Library Editor. It will.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Keet at Apr 2, 2024, 12:04:28 PM |
Re: Sweet Home 3D 7.3 When you select a single object in the 3D view the keyboard combo ctrl+E works to get the modify dialog but not if you select multiple objects in the 3Dview. I just tried under Windows, macOS and Linux, but didn't notice this issue. It would be astonishing that a plug-in could alter this behavior.Since ctrl+E does work with a single object it's not likely that the keyboard event is caught by something else. Multiple selects of walls or rooms work as they should (ctrl+shift+E and ctrl+alt+E). Maybe worthy to note: select multiple furniture in the 3Dview and add another one to the selection in the 2Dview. Now ctrl+E does work for the multi-selection. Even select/unselect an additional object in the 2Dview makes it that ctrl+E does work. It seems that a multi-selection only in the 3Dview isn't recognized for the keyboard event. Using the context menu does work but it requires to leave the keyboard and use the mouse. This is with Sweet Home 3D 7.3 beta 1 on Debian Linux (tested on two different Debian versions, host and VM). Version 7.2 has the same problem. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Keet at Apr 2, 2024, 7:08:08 PM |
Re: Sweet Home 3D 7.3 A strange one: Unviewable tab captions are no longer grayed out when the tab/level is made unviewable. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Apr 2, 2024, 7:56:35 PM |
Re: Sweet Home 3D 7.3 A strange one: Unviewable tab captions are no longer grayed out when the tab/level is made unviewable. Yes, I know, it's my fault, I made a temporary change for tests purpose and forgot to roll back the change. It's fixed in Beta 2 where German help was updated thanks to Waldemar Hersacher.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Waldemar.Hersacher at Apr 2, 2024, 8:37:30 PM |
Re: Sweet Home 3D 7.3 Originally when you imported furniture the object had to be in a category. This landed a lot of furniture in the Bathroom category because that was the first in the list. I think it was in version 7.02 that a checkbox 'Add to catalog' was added which lets you choose whether or not to add your import to a category. Unchecked the imported object was not added to the catalog. In 7.2 The User category was introduced as a default category. With the checkbox 'Add to catalog' unchecked imports were still added to the catelog in the User category. With the checkbox unchecked the import should not have been added to the catalog at all. In the latest 7.3 beta-1 this is solved so that when 'Add to catalog' is uncheked the import is not added to the catlog. This was a failure of the tester. I wasn't aware of the regression so when I first tested it I didn't go any possible ways and maybe I didn't reset the catalogue to the default contents at any time. With your description Keet I can confirm that it is solved. I have left out some updates because the version before 7.2 was 6.x. ---------------------------------------- MSI GP60, Linux Mint 21.3 Virginia base: Ubuntu 22.04 jammy, SH3D 7.5 with Photo-video rendering 2.8 |
| Posted by Waldemar.Hersacher at Apr 2, 2024, 9:10:38 PM |
Re: Sweet Home 3D 7.3 When you select a single object in the 3D view the keyboard combo ctrl+E works to get the modify dialog but not if you select multiple objects in the 3Dview. I just tried under Windows, macOS and Linux, but didn't notice this issue. It would be astonishing that a plug-in could alter this behavior. I used the 2 Bedrooms house with basement again. I selected in 3D-View the corner sofa and the table (a cylinder) before it. Ctrl+E is opening the Modify furniture dialogue. The only plugin I have installed is the Photo-Video rendering plugin 2.7. Tested wit 7.2 and 7.3 Beta 2 on Linux. ---------------------------------------- MSI GP60, Linux Mint 21.3 Virginia base: Ubuntu 22.04 jammy, SH3D 7.5 with Photo-video rendering 2.8 |
| Posted by Keet at Apr 2, 2024, 9:39:46 PM |
Re: Sweet Home 3D 7.3 I just tried under Windows, macOS and Linux, but didn't notice this issue. It would be astonishing that a plug-in could alter this behavior. And yet that is exactly what happens. I have 21 plugins installed. I uninstalled them all and ctrl+E functions as it should. One-by-one I added the plugins again and the Pan3Dview plugin is causing the problem. With all other plugins re-installed except Pan3Dview ctrl+E works, add Pan3Dview and it no longer works. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Apr 4, 2024, 10:22:34 PM |
Re: Sweet Home 3D 7.3 I released the version 7.3 today. Thanks again for your tests! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 23, 2026, 12:34:34 PM |
