Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Maximum size of a plug-in |
| Print at Sep 24, 2026, 1:39:12 AM | |
| Posted by enkonyito at Apr 7, 2024, 12:07:43 AM |
Maximum size of a plug-in Is there a maximum size a plug-in can be added into the Sweet Home 3D project on SourceForge? For a 15.5MB plug-in, I get the message: "413 Request Entity Too Large". ---------------------------------------- EnkoNyito |
| Posted by Keet at Apr 7, 2024, 7:38:35 AM |
Re: Maximum size of a plug-in There are limits on file size: https://sourceforge.net/p/forge/documentation...r%20Web/#file-size-limits but this is probably not your problem. 15.5 MB should not be a problem. Maybe it's related to this: https://sourceforge.net/p/seeddms/discussion/general/thread/133a634a/ I don't know how sourceforge is setup but maybe these instructions can help: https://popart-studio.medium.com/what-is-a-41...ow-to-fix-it-9f07fffdcc92 (heading "Modifying the PHP ini File") ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Daniels118 at Apr 7, 2024, 1:02:36 PM |
Re: Maximum size of a plug-in You could also try to compress the jar with a higher compression level to shrink its size. By the way I'm curious about what make your plugin so large. |
| Posted by Puybaret at Apr 7, 2024, 1:41:57 PM |
Re: Maximum size of a plug-in I don’t have access to this kind of parameters on SourceForge, but they already increased the size limit of attached files in the past. If you want to make your plug-in smaller, you could compile your class files without debug information (Enkonyito already zip them). His plug-ins are large because they include YafaRay DLLs. Enkonyito, if you don’t find a solution on SourceForge, send it to me, I’ll host your plug-in on sweethome3d.com server. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Daniels118 at Apr 7, 2024, 3:03:27 PM |
Re: Maximum size of a plug-in But considering that yafaray dll is now part of SH3D itself, I see no pratical reason to include it in the plugin. It could worth to think about it. |
| Posted by enkonyito at Apr 8, 2024, 12:31:15 AM |
Re: Maximum size of a plug-in @Puybaret Thanks for the suggestion, it might be useful in the future. For the moment, I applied this solution. @Daniels118 Unfortunately, using the DLLs of the version of YafaRay integrated into Sweet Home 3D causes the error java.lang.UnsatisfiedLinkError: YafarayRenderer.createEnvironment(Ljava/lang/String;Ljava/lang/String;)J---------------------------------------- EnkoNyito |
| Posted by Daniels118 at Apr 8, 2024, 7:19:41 PM |
Re: Maximum size of a plug-in You should try to not call initdll at all, they are already loaded. |
Current timezone is GMT Sep 24, 2026, 1:39:12 AM |
