Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Changing output resolution |
| Print at Sep 26, 2026, 11:08:05 AM | |
| Posted by msabell at Apr 11, 2024, 1:25:44 AM |
Changing output resolution Hi all, I've been using Sweet Home 3D for a year or so now, love it except I would like to be able to output in a higher resolution and don't know how. I use SH3D for 2D drawing of floorplans, export as a PDF and add in my own fixtures and final touches to present a final plan for the client. I'm noticing when I export to PDF it doesn't really give me high resolution, and wanted to know how this can be achieved as I've seen in other threads the DPI can be changed? |
| Posted by Puybaret at Apr 11, 2024, 2:36:07 PM |
Re: Changing output resolution In case you want nicer images for the furniture drawn in the plan, you could increase the Icon size parameter in the prefernces pane. Of course the highest value will make the program use much more RAM. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by iTwo at Sep 10, 2024, 9:22:49 PM |
Re: Changing output resolution It's not just furniture. The resolution of the PDF output is low for walls and polylines also. |
| Posted by Xlance at Mar 23, 2025, 8:39:40 AM |
Re: Changing output resolution Hello Check this out.It can export images to extremely large sizes, adjust DPI and print sizes 😀 https://sweethome3d.com/support/forum/viewthr...862_lastpage,yes#lastpost Enjoy ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
Current timezone is GMT Sep 26, 2026, 11:08:05 AM |
