Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate PDF file. |
| Print at Sep 24, 2026, 12:50:57 AM | |
| Posted by AlexDeveloper at Apr 11, 2024, 11:55:28 PM |
Generate PDF file.Hello, I am appealing to this developer audience with a problem that I have faced. I have made some changes to the drawing wall. Changes are labeled on the center of each wall and show the length of the wall (see video - link ). My problem is that when I want to export the plan in a PDF file white labels that are on the center of each wall do not export in PDF and I see just black walls without white labels (see vide - link). But when I use a plugin "Export plan to PNG" everything works correctly (see screenshot - link ). here is a code changes in the method paintWalls - link brief code: Thank you very much for your help!! ![]() |
| Posted by sjb007 at Apr 12, 2024, 3:47:21 AM |
Re: Generate PDF file. I'm curious, does exporting to SVG correctly show your wall labels? There's a PaintMode (PAINT, PRINT, CLIPBOARD, EXPORT) which is selecting different bits of code in the PlanComponent.java file depending on if you are painting to screen, printing, exporting to SVG, or copying to clipboard. The answer might lie in that code. (Not a dev, just a tinkerer.) |
| Posted by sjb007 at Apr 12, 2024, 3:48:57 AM |
Re: Generate PDF file. Oh, to be clear... It looks like PDF is using the PRINT mode, and SVG uses the EXPORT mode. Obviously PAINT is for rendering to screen. |
| Posted by [email protected] at Apr 12, 2024, 11:08:38 AM |
Re: Generate PDF file. Good morning I read your trend's email. I am not a programmer, but I can say that I fully agree with Sib007, given that PDFs (Portable Document Files) are by their constructive and historical characteristic an evolution of the Postscript PRINT language (also from Adobe), both logical and any autonomous source of Building a PDF file actually uses PRINT instructions |
| Posted by AlexDeveloper at Apr 12, 2024, 12:17:39 PM |
Re: Generate PDF file. Exporting to SVG works correctly - see link |
| Posted by AlexDeveloper at Apr 12, 2024, 12:54:56 PM |
Re: Generate PDF file. But in PAINT mode still do not draw white labels on the walls(( |
| Posted by Daniels118 at Apr 12, 2024, 3:51:41 PM |
Re: Generate PDF file. Are you REALLY sure that labels aren't painted? It could be that in PDF they are drawn by default using transparent background, so the text cannot be seen. Try to select the text in the exported PDF, if the labels are there, then you should see the text highlighted. If this is so, then you could simply set the background color; if background color isn't an available feature, just draw a rectangle before drawing the text. Just courious: why in the world are these variables called this way? Have you used a decompiler to get the source code? You should know that this is an open source software, so you can get the original sources. |
| Posted by AlexDeveloper at Apr 12, 2024, 4:33:10 PM |
Re: Generate PDF file. Thank you for your answer! Yes, you are right) text on the wall exists but they are under a black layer but without a little white background as on the sweethome3d editor. check screenshot - link but I think I need a programmer who has a lot of experience contributing to this application and maybe can make me a point about why it is as is. what bout the code it is from my friend jar and I am gonna rename the variables. I am developing a very useful plugin for myself maybe for the public. |
| Posted by AlexDeveloper at Apr 14, 2024, 9:07:37 PM |
Re: Generate PDF file.Someone can help me? ![]() |
| Posted by Puybaret at Apr 15, 2024, 11:23:44 AM |
Re: Generate PDF file. First thing, if you want some help, you have to help programmers understanding your code too. Naming every variable varsomething is really troublesome and in the long term, it won't help your code maintenance. Some comments could be welcomed too, at least to show where you made some modifications. Then, in your code: if (home.wallType.contains(var18.getModeCreationName())) {Did you try to print, instead of printing to PDF? Then, try to print through a PDF printer driver? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 12:50:57 AM |
