Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: objects elevation |
| Print at Sep 26, 2026, 1:06:58 PM | |
| Posted by thebandix at Feb 1, 2010, 7:56:27 AM |
objects elevation My problem is simple: I can't put objects with an elevation over 1000mm. I need to put some elements, especially in a kitchen, far above this limit: for example the hood should have an elevation of about 1800-2000. How can I bypass this problem? txs in advance |
| Posted by Puybaret at Feb 1, 2010, 8:17:49 AM |
Re: objects elevation Please use temporarily an other unit in Preferences dialog. In version 2.2, the max elevation is 1000 whatever the unit you chose. I'm going to fix that. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 1:06:58 PM |
