Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Taking too much time to render. Can someone help please? |
| Print at Sep 24, 2026, 1:40:33 AM | |
| Posted by ArvinJo8 at Apr 14, 2024, 6:12:23 AM |
Taking too much time to render. Can someone help please? Taking too much time to render. Can someone help please? PC Specs Window 11 Pro Graphic Geforce RTX Nvidia 3080 i7 12300 32gb ram 1tb ssd 1tb hdr Only 4% of GPU is in use and 25% of CPU (how to increase it consumption so as to make the rendering much faster?) Paid version of Sweet Home 3d from Microsoft Store All plugin install |
| Posted by Keet at Apr 14, 2024, 8:26:38 AM |
Re: Taking too much time to render. Can someone help please? The current renderers (SunFlow & YafaRay) use the CPU for rendering, not the GPU so it's no surpise that the GPU load is low. What you can try is to increase the amount of memory Sweet Home 3D is allowed to use. This might avoid some swapping and should increase the overall speed. How-to is described here: http://www.sweethome3d.com/faq.jsp#increaseMaxMemory The time needed to render mainly depends on the complexity of what you render. A tree takes a lot longer than a simple box. Textures take more time than colors. If you can simplify the scene you want to render this should help more than anything else you can do. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by hansmex at Apr 14, 2024, 12:00:01 PM |
Re: Taking too much time to render. Can someone help please? General tips to reduce render times: - use small models (in Kb) with low poly count (e.g. avoid trees/plants) - use few light sources - avoid mirrored and/or transparent surfaces/objects - make invisible what is not in the image (models/levels) - use no or small textures (512x512 pixels is generally enough) H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by subia75 at Aug 7, 2024, 3:38:53 PM |
Re: Taking too much time to render. Can someone help please? Hi, I'm connecting to this post, I took back my file of my house with garden after 2 years because I made some changes. It's a 200mb file but, I remember that it took me 15/20 minutes to render Now for the same file it takes more than 1 hour. I don't understand why. I always use the same PC, so could it be that there is some difference in the program after 2 years of updates? I'm thinking of trying an old release to see if it was lighter. |
| Posted by Puybaret at Aug 7, 2024, 9:57:28 PM |
Re: Taking too much time to render. Can someone help please? Run again the installation program and select the 64 bit architecture when prompted. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by subia75 at Aug 8, 2024, 9:36:30 AM |
Re: Taking too much time to render. Can someone help please? Hi, if the answer was for me, the installation is already 64bit |
| Posted by Puybaret at Aug 8, 2024, 10:42:54 AM |
Re: Taking too much time to render. Can someone help please? Did you select YafaRay rendering engine? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by subia75 at Aug 8, 2024, 12:35:59 PM |
Re: Taking too much time to render. Can someone help please? I use Sunflow, I'll try to do some tests with YafaRay. Then I'll let you know how they went. thanks |
| Posted by Keet at Aug 10, 2024, 12:52:38 PM |
Re: Taking too much time to render. Can someone help please? Did you try to render at the same resolution as before? A higher resolution takes longer to render. Unless you know what resolution you used for the old rendering it's easy to make the 'mistake' of trying to render with a higher resolution. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by subia75 at Aug 12, 2024, 12:54:32 PM |
Re: Taking too much time to render. Can someone help please? Yes, I'm sure of the same resolutions because I save a scrren of the settings I use. I also tried with YafaRay engine but it takes longer. As soon as I can I try to load an older release just to do a further test. |
Current timezone is GMT Sep 24, 2026, 1:40:33 AM |
