Print at Sep 30, 2026, 2:10:41 AM
Posted by hweyer at Feb 1, 2010, 12:31:50 PM
3D Driver problem
Hello -
I have installed the latest version of Sweet Home (2.2). In the
beginning, things looked OK and I was able to define a room and save it.
But whe I open this file I get an error message (wording may not be
literal as I translated it from German) " Sweet Home 3D is terminated
because of a severe rendering error. Please update the
drivers of the graphic card."
I am running Sweet Home on an E8310 Lifebook, which to my knowledge
does not have a graphic card. In addition, the same error message
is generated independent of using the built-in laptop display or
an external monitor.
What can I do?
Thanks
Heinz J
Posted by Puybaret at Feb 1, 2010, 1:05:57 PM
Re: 3D Driver problem
Even netbooks have at least some kind of integrated graphic card and/or drivers for it, otherwise there wouldn't be anything on screen!
On what system are you trying Sweet Home 3D?
If you're on Windows, did you try the solutions described in the FAQ?
Posted by hweyer at Feb 1, 2010, 1:48:56 PM
- I am running XP.
- thanks for pointing to the FAQ.
Heinz J
