Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Beveled edge window 30 degrees |
| Print at Sep 27, 2026, 4:27:55 PM | |
| Posted by Mike1971 at Apr 19, 2024, 10:46:34 AM |
Beveled edge window 30 degrees Hello! i¨m new here and trying to create my own cabin. I'm looking for a fixed window with beveled edges as shown in picure. 1100mmX1400mm bevel 30 degrees. Does anyone know where i can get (buy) this 3D model that i can use in Sweet Home 3D? Thanks! https://www.turbosquid.com/FullPreview/593027 |
| Posted by Puybaret at Apr 19, 2024, 1:02:55 PM |
Re: Beveled edge window 30 degrees Here's a version derived from the fixed window model available in the default catalog. You'll just have to set its size and don't forget to select the Door or window option when you import it. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Mike1971 at Apr 19, 2024, 3:19:15 PM |
Re: Beveled edge window 30 degrees Thank you so much, Puybaret! ![]() |
Current timezone is GMT Sep 27, 2026, 4:27:55 PM |
