Print at Oct 13, 2026, 3:30:29 AM
Posted by zazay at Apr 29, 2024, 5:04:43 PM
confused   Can i import images ?
Hi
Can i import images to my 3D plan (i'm not talking about the background image) ??
if the answer is yes, then how ? confused
Posted by Puybaret at Apr 29, 2024, 5:49:11 PM
Re: Can i import images ?
What are you trying to achieve?
Posted by Keet at Apr 29, 2024, 6:00:34 PM
Every texture is an image. When you apply a texture to a surface you effectively import an image to show on that surface.
But the answer to Emmanuel's question "What are you trying to achieve?" can determine if applying a texture can solve your problem.
One very interesting topic in this forum is from GaudiGalopin3324. I once gave him a simple idea and test model to integrate photo's as replacement for 3D models and he took a run with it. He made some amazing progress in integrating photo's in his Sweet Home 3D projects. Start reading here where I gave him the first model and read about the great results he got with lots of experimenting: https://sweethome3d.com/support/forum/viewthread_thread,12648_offset,60#61022
