Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Go to point of view don't work |
| Print at Sep 23, 2026, 9:53:02 PM | |
| Posted by ebrien at Jun 14, 2024, 10:40:53 PM |
Go to point of view don't work SweetHome 3D: 7.4 Macbook pro (Retina 15, Late 2013) I know it's old but still works well MacOS 11.7.10 I made my floor plan and I want to create multiple pictures with different lights open to build my dashboard for Home Assistant... Every time I change the light I want to be visible, the point of view changes and when I select "Go to Point of View", nothings happens. Thanks in advance. |
| Posted by Puybaret at Jun 14, 2024, 11:41:55 PM |
Re: Go to point of view don't work If you activated the Aerial view centered on selection option in the preferences pane, an Aerial point of view (stored or not) depends on the current selection. Either select again the same object(s) to get exactly the same point of view or use points of view in Virtual visit mode. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ebrien at Jun 16, 2024, 8:27:14 PM |
Re: Go to point of view don't work Thank you @puybaret, that fixed it. Merci! |
Current timezone is GMT Sep 23, 2026, 9:53:02 PM |
