Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Rendering without ground and sky? |
| Print at Oct 2, 2026, 10:07:16 AM | |
| Posted by Xiste at Jul 11, 2024, 10:59:08 PM |
Rendering without ground and sky? I just wonder; is it very difficult to make ground and sky totally transparent so we are just left with the furniture/objects when rendering? |
| Posted by hansmex at Jul 12, 2024, 12:52:51 AM |
Re: Rendering without ground and sky? Apply a transparent texture to both? Or is that beyond the point? ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Daniels118 at Jul 12, 2024, 6:39:55 AM |
Re: Rendering without ground and sky? The sky is unlit, so you can set it to any color you want. The ground will always be affected by shadows, and I'm quite sure it doesn't support transparency. But maybe you also want alpha channel in the output image? |
| Posted by Puybaret at Jul 12, 2024, 8:01:51 AM |
Re: Rendering without ground and sky? If you select a white texture for the ground and the sky, then render your design in Virtual visit mode, you'll get an image that you can easily cut out. But there's no alpha channel option. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Xiste at Jul 12, 2024, 10:54:50 AM |
Re: Rendering without ground and sky? The sky is unlit, so you can set it to any color you want. The ground will always be affected by shadows, and I'm quite sure it doesn't support transparency. But maybe you also want alpha channel in the output image? Yes, an alpha channel would have been super! Shadows on the ground are eliminated with a luminous backdrop, so that's no problem. |
| Posted by Daniels118 at Jul 12, 2024, 10:29:19 PM |
Re: Rendering without ground and sky? For single picture you can easy cut the background color using photo processing programs. For example photoshop has a background eraser tool, or you could try an AI service. |
| Posted by Xiste at Jul 13, 2024, 2:07:16 AM |
Re: Rendering without ground and sky? For single picture you can easy cut the background color using photo processing programs. For example photoshop has a background eraser tool, or you could try an AI service. Yes, and that's the whole point of a luminous backdrop. Keying works best when there are no shadows. Photoshop is not so good. Aftereffects or DaVinci Resolve are my preferred tools. Xiste |
| Posted by Daniels118 at Jul 13, 2024, 10:51:49 PM |
Re: Rendering without ground and sky? If you have basic programming skill, you may try to edit the advanced photo/video render plugin to remove the code that draws the ground. |
| Posted by Xiste at Jul 14, 2024, 1:26:21 AM |
Re: Rendering without ground and sky? If you have basic programming skill, you may try to edit the advanced photo/video render plugin to remove the code that draws the ground. He, he - no, I don't do more than html when it comes to coding, but if it is easy for a programmer with basic knowledge, maybe someone will do it for money? Spread the word! Xiste |
Current timezone is GMT Oct 2, 2026, 10:07:16 AM |
