Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Roof view from inside |
| Print at Oct 2, 2026, 12:44:22 PM | |
| Posted by Bobby_21 at Aug 9, 2024, 9:51:52 PM |
Roof view from inside Hi, I’m a newbie and have just started using the generate roof plugin. When trying to draw a bungalow, should I see the inside of the roof from in the building? This is what I am trying to do. |
| Posted by Keet at Aug 10, 2024, 7:14:03 AM |
Re: Roof view from inside Right click in the 3Dview and select 'Virtual visit'. That gives you a camera you can position to view the inside of the roof. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Bobby_21 at Aug 10, 2024, 9:24:17 AM |
Re: Roof view from inside Thank for the post Keet. If I do this i just see blue above me. The only way I can see the roof is if I change from level 1-dim to roof-gen but then I can only see the whole building if i place the camera outside, from inside i just see the roof structure, not the actual room. |
| Posted by Puybaret at Aug 10, 2024, 9:59:41 AM |
Re: Roof view from inside Maybe you didn’t select the 3D View > Display all levels menu item. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Bobby_21 at Aug 10, 2024, 1:12:15 PM |
Re: Roof view from inside Thank you very much Puybaret, that did it. |
Current timezone is GMT Oct 2, 2026, 12:44:22 PM |
