Print at Sep 26, 2026, 5:39:17 AM
Posted by hansmex at Feb 16, 2010, 3:44:52 PM
Strange behaviour
Emmanuel:
In the attached file two things are more or less abnormal:
1 - The texture of the wall is striped. This happens sometimes in models, but I'm not sure why.
2 - The invisible wall opening keeps showing one side of the wall after "magnetic" insertion. I've used this self-made model/object many times before without any problems. I have the feeling that this problems occurs in the last few betas only, but I'm not entirely sure of it. I can easily solve the problem by making the object a bit "thicker", so it's more out of curiosity that I wanted to show you this.
Attachment Suurupi House.sh3d (870968 bytes) (Download count: 707352)
Posted by Puybaret at Feb 19, 2010, 9:52:45 PM
Re: Strange behaviour
The texture is striped because a 3D wall is in fact made of two thiner walls one for the left side and the other one for the right side. The strips appear in the 3D view when the two sides don't have the same color and are very far.
I fixed it in Sweet Home 3D 2.3 Beta, by removing the useless parts in the middle of the wall.
Don't hesitate to test this change on many SH3D files to check I didn't miss something.
