Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: visual 3d rendering problem with v7.5 under windows 11 |
| Print at Sep 23, 2026, 9:53:01 PM | |
| Posted by peefy at Sep 10, 2024, 4:32:25 AM |
visual 3d rendering problem with v7.5 under windows 11 visual 3d rendering problem with v7.5 under windows 11 The 3d view shows strange lines, see picture below I included the sh3d file so you can see for yourself link to image: https://drive.google.com/file/d/1d7xPG4KWPSVu...r-BWXTag/view?usp=sharing link to sh3d file: https://drive.google.com/file/d/17fp1zGtNNOrD..._czb41Gu/view?usp=sharing Any solutions for this problem? thanks!! |
| Posted by Puybaret at Sep 10, 2024, 8:23:56 AM |
Re: visual 3d rendering problem with v7.5 under windows 11 It's a known bug in Adrenalin graphics driver. Either you install Sweet Home 3D 64 bit (run installer again and select 64 bit architecture when prompted), or you update Adrenalin graphics driver. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Sep 10, 2024, 8:31:35 AM |
Re: visual 3d rendering problem with v7.5 under windows 11 When I open your file and make a render, I get a very different result from yours. Please, share the EXACT file that causes the problem. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by peefy at Sep 10, 2024, 3:32:37 PM |
Re: visual 3d rendering problem with v7.5 under windows 11 Thank you guys, I did not see the 64bit option at first, it seems to work now! suggestion: maybe it is a good idea to make the 64bit version the default selection! |
Current timezone is GMT Sep 23, 2026, 9:53:01 PM |
