Print at Oct 14, 2026, 9:24:55 AM
Posted by wsky at Oct 17, 2024, 9:44:17 PM
Critical error in 3D rendering with Linux and Nvidia driver (v7.5)
Hi there, I can not start Sweet Home 3D with the standard script, only getting an error message about a critical error in rendering system and I should update the graphics driver, then it quits. However it's the latest driver that is currently available on Ubuntu 24.04 which is Nvidia driver 550.107.02
I can use the other script "SweetHome3D-Java3D-1_5_2" to start Sweet Home 3D and it seems to work fine.
Here is the shell output from the normal start script:
Failed to load module "canberra-gtk-module"
com.jogamp.opengl.GLException: J3D-Renderer-1: Error making temp context(1) current: display 0x7e0dec20a270, context 0x7e0dec242188, drawable X11OnscreenGLXDrawable[Realized true,
Factory jogamp.opengl.x11.glx.X11GLXDrawableFactory@4d3fbd1c,
Handle 0x5a0009b,
Surface JAWTWindow[0x31d9eebc][JVM version: 1.8.0_202 (1.8.0 update 202)
JAWT version: 0x10004, CA_LAYER: false, isLayeredSurface false, bounds [ 0 / 0 813 x 522 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], pixelScale 1.0x1.0, shallUseOffscreenLayer false, isOffscreenLayerSurface false, attachedSurfaceLayer 0x0, windowHandle 0x5a0009b, surfaceHandle 0x5a0009b, bounds [ 0 / 0 813 x 522 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], window [0/0 813x522], pixels[scale 1.0, 1.0 -> 813x522], visible true, lockedExt false,
config AWTGraphicsConfiguration[AWTGraphicsScreen[AWTGraphicsDevice[type .awt, connection :0.0, unitID 0, awtDevice X11GraphicsDevice[screen=0], handle 0x0], idx 0],
chosen GLCaps[glx vid 0x28, fbc 0xaf: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]],
requested GLCaps[rgba 5/5/5/1, opaque, accum-rgba 0/0/0/0, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]],
X11GraphicsConfig[dev=X11GraphicsDevice[screen=0],vis=0x28],
encapsulated X11GLXGraphicsConfiguration[X11GraphicsScreen[X11GraphicsDevice[type .x11, connection :0, unitID 0, handle 0x7e0dec20a270, owner true, JAWTToolkitLock[obj 0x12f3c656, isOwner true, <5f7940aa, 6f9ec104>[count 1, qsz 0, owner <J3D-Renderer-1>]]], idx 0], visualID 0x28, fbConfigID 0xaf,
chosen GLCaps[glx vid 0x28, fbc 0xaf: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]]]],
awtComponent com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D[canvas2,0,0,813x522],
surfaceLock <209027c2, 22644e67>[count 1, qsz 0, owner <J3D-Renderer-1>]]]
at jogamp.opengl.x11.glx.X11GLXContext.createImpl(X11GLXContext.java:393)
at jogamp.opengl.GLContextImpl.makeCurrentWithinLock(GLContextImpl.java:794)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:677)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:615)
at javax.media.j3d.JoglPipeline.createNewContext(JoglPipeline.java:6411)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4612)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2386)
at javax.media.j3d.Renderer.doWork(Renderer.java:881)
at javax.media.j3d.J3dThread.run(J3dThread.java:271)
Error in Java 3D : 3 Renderer: Error creating Canvas3D graphics context
Posted by Keet at Oct 18, 2024, 12:58:40 PM
Re: Critical error in 3D rendering with Linux and Nvidia driver (v7.5)
On Linux always use the "SweetHome3D-Java3D-1_5_2" script. I use it on Debian.
Posted by scjo at Oct 25, 2024, 11:51:55 PM
wsky,
I'm late. Could you meanwhile sort it out? If so: was it Keet's suggestion or another solution?
Emmanuel Puybaret suggested an additional java parameter:
-Dcom.eteks.sweethome3d.j3d.version=1.5.2
for the furniture library editor, a java app by him as well.
I'm using nvidia, too. The only thing that helped me was a switch from the proprietary driver to the open source nouveau (see link above).
However, nouveau is not the greatest driver either due to nvidia's denial of support. I'm cured from nvidia.
Cheers - Joe //
Posted by wsky at Oct 26, 2024, 12:34:49 PM
Hello scjo, starting Sweet Home 3D from shell like this?
./SweetHome3D -Dcom.eteks.sweethome3d.j3d.version=1.5.2
This doesn't work, it will open the splash screen and then does nothing until I send Ctrl-C to the process.
For now, I am always using "SweetHome3D-Java3D-1_5_2" to start.
And also I am waiting for the Nvidia driver 560 or later to be available with the driver updater on Ubuntu 24.04. Currently 550 is the latest available but I had 560 on Ubuntu 22.04.
Furthermore, I'm using the "open" Nvidia driver 550 though the proprietary driver 550 is shown as recommended. I haven't tested yet if Sweet Home 3D (standard starter) works with the proprietary driver.
Posted by scjo at Oct 28, 2024, 12:47:19 AM
In your command, SweetHome3D is probably a shell script. Open it with any text editor, and find the "exec" line. Mine starts with:
exec "$PROGRAM_DIR"/runtime/bin/java
More towards the end of the line, maybe several screen lines below, if your editor does auto linewrap, you find some parameters starting " -D...". Among these, surrounded by spaces but no hard line breaks of course, insert the additional parameter string.
My java knowledge is very limited, I don't even know if the sequence of parameters matters. But it won't hurt either.
HTH
Cheers - Joe //
