Print at Oct 3, 2026, 9:50:42 AM
Posted by shyne at Oct 27, 2024, 7:08:15 AM
confused   Do you have "freeizing" problems on your MAC?
SH3D freezes very often. I force it to quit and reopen. This is a not so smooth workaround. Does anybody else have similar issues? Is there a known solution?
I hoped the Update of Macos or SH3D would help. Since I have the problem, there were several updates. Didn't help :(
I use a 14'' Silicon Chip Macboook. Now I use MacOS 15.0.1 (24A348). Before I used Macos 14. The problems was there before and I am not sure if it is worse now. I also use a second Macbook as a second monitor (which also causes freezing, especially after closing / opening the mac - connect / disconnect)
