Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Stair builder |
| Print at Sep 23, 2026, 9:52:52 PM | |
| Posted by dorin at Nov 1, 2024, 8:36:53 PM |
Stair builder Continuing the YAUP series I made this Stair builder v.1.0 beta1 . I've modify and improve (I think) the plugin previously made by Emmanuel. I don't know if it's right or wrong in terms of licenses, but I did it for my personal use and some friends. Basically, I modified the existing ones and added about 500 lines. 1. I've add poly lines for 2D representation (edges and direction) 2. After three months of study I tried to implement some international requirements in this field. I also tried to be self-explanatory, but this cannot replace user knowledge. So, for more information, you could read this (and many others): https://inspectapedia.com/Stairs/Ideal-Stair-Design-Specifications.php https://inspectapedia.com/Stairs/Stair_Winders.php https://www.practicalarchitecture.com/blog/th...f-a-comfortable-staircase https://www.zhitov.com/en/lestnica3/ Anyway, few pictures: ![]() ![]() ![]() ![]() ![]() ![]() ![]() That's all until now. There is many more to do. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Keet at Nov 2, 2024, 8:47:51 AM |
Re: Stair builder Great additions Dorin! The added polylines for the 2D view make it clear which part starts at the bottom and which part ends at the top. Personally I don't use the staircase generator much because I custom create all my staircases. I mainly use it to calculate the dimensions The one thing that I think it needs most is a way to vary the post/baluster/handrail types. You can create a dozen different staircases but they will still all look more or less the same because all balusters, posts, and handrails are the same. I'm not sure if this is difficult or even possible. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by scjo at Nov 2, 2024, 4:22:51 PM |
Re: Stair builder Fantastic! When I recently modelled my home I missed such a tool very much for the helical stairs with rectangular outlines. I will add them as soon as my shelves are done. ---------------------------------------- Cheers - Joe // |
| Posted by Keet at Nov 2, 2024, 6:32:13 PM |
Re: Stair builder Fantastic! When I recently modelled my home I missed such a tool very much for the helical stairs with rectangular outlines. I will add them as soon as my shelves are done. The Staircase Generator plugin was created and introduced on December 13, 2022 by Emmanuel Puybaret, so it's been around for a while. Dorin is adding some extra features. That's the beauty of open source software!---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by dorin at Nov 4, 2024, 12:10:01 PM |
Re: Stair builder StairBuilder v.1.0 beta2 * Stair builder-1.0 beta2 news: -add a CHANGELOG.TXT -fix the bug created by me on the cut out shape for round spiral stairs -fix a bug in information label for tread width when other option than Square Spiral are selected -have adjusted some translations accordingly with sjb007 & Keet's suggestions -set the author name to "anonymous" until will be a dedicated text field for this. TODO (or at least what I intend to do): -to implement somehow a customizable cut-out-shape in respect of minim headroom requirement. -to add somewhere a picture with the specific terms used on stairs. I intend to change again the names accordingly to this. Like: -"Riser" in place of "Last step elevation" -"Run" in place of "Tread depth" -"Rise" in place of "Tread height" -"Nosing" in place of "Tread offset" etc. But I have to explain somehow to the users who know nothing about that terms. @Keet Almost everything it is possible but not all are easy. All components of this stair are generated by extrusion. I don't have enough knowledge about 3D object manipulation so, you will have to wait until I will learn. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by scjo at Nov 4, 2024, 7:23:21 PM |
Re: Stair builder Dorin is adding some extra features. That's the beauty of open source software! Indeed it is. Plus some more advantages. I wish I could clone several instances of myself, like in a parametric CAD system. One of them would learn python, one java and together they would support a third one in collaborating with dorin on 3D geometry, using the guts of FreeCAD as a quarry.---------------------------------------- Cheers - Joe // |
| Posted by Keet at Nov 4, 2024, 7:46:29 PM |
Re: Stair builder But I have to explain somehow to the users who know nothing about that terms. To name the parts of my custom staircases I did a search for "staircase parts diagram". Many results with excellent examples. Use one of the search results as an example to add names to an image of a generated staircase. Don't use one of the images you find, they might be copyrighted. Display it under a button or in the manual. (There are some strange names, like 'Kite winder' )---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by scjo at Nov 4, 2024, 8:44:58 PM |
Re: Stair builder Any use for a German translation of the UI? I'm willing. ---------------------------------------- Cheers - Joe // |
| Posted by dorin at Nov 4, 2024, 9:27:04 PM |
Re: Stair builder @scjo Of course I will need and thanks for your willing. At this moment is not established the English part as nor for any other languages. I hope will be sometime in the future. @Keet You're right about images and the probably copyrights. Anyway my needed image is not invented yet so, as in linux philosophy, I'll drawn myself. Probably I will use numbers in place of terms and the same numbers at corresponding input. In this way I could avoid to make 20+ pictures corresponding to every available language. At the moment I'm not satisfied how the stair is generated in some circumstances. It need to be a strictly correspondence between inputted values and the final results. Now is not always the case. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by dorin at Nov 12, 2024, 5:03:02 PM |
Re: Stair builder StairBuilder v.1.0 beta3 I continue to bore you with my ramblings. Probably this version will be the last with the classical look. I intend to modify it accordingly with my taste. From CHANGELOG: -decide to use terms accordingly with https://inspectapedia.com/Stairs/Ideal-Stair-Design-Specifications.php -improve round spiral stair calculation -set turn step count as default for squared turn stair in place of step count -add slope percent values -fix partially job results for squared turn stair TODO: -generate the custom cut out shape for all but especially for round spiral stairs -add pre-maded localization files for all available languages Disclaimer: Not always is WYSIWYG. Most of the calculus I suppose it is correct but their interpretation need to be improved. So, USE IT WITH CARE! ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by voisin at Dec 13, 2024, 2:19:53 PM |
Re: Stair builder I am impressed with the modifications made on this plugin. I have encountered a bug on a Mac. The top of the stair builder window. Is chopped of. I cannot select the type of stair case or enter the top parameters. I hope you would be able to fix the problem. Perhaps a scroll??? Or an ability to enlarge the pop-up window??? Many thanks Daniel |
| Posted by voisin at Dec 16, 2024, 4:21:08 PM |
Re: Stair builder @Dorin Many thanks for the great adaptions on the existing plug-in. I have encountered a bug on... Sweet Home 3d version 7.5 on the Mac. OpenJDK 15.0.10 on ARM Stairbuilder v.1.0 beta 3 I am missing the top part of the popup window. The first two parameters: Stair type and stair count. It is like the window is just not big enough. There is no options to stretch or expand the window, nor no scroll bars. Is there anything you can do to fix this problem? many thanks ![]() |
| Posted by dorin at Dec 17, 2024, 8:56:04 PM |
Re: Stair builder You've right! I've encountered the same problems under linux with Nimbus LaF. I'll fix-it when times come. Until than I try to make this plugin to respect the general requirements of ergonomic and safety. I still have to find solutions for another 150 to 300 possibly variants. I can't promise when, especially because I do it for may personal use. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by dorin at Feb 10, 2025, 8:03:15 PM |
Re: Stair builder Rules for stairs 1. TREADS (STEPS) Depth The tread depth (run) of staircase have to be measured from left side or inner: - at 50 cm if wide is <=1 m and - at 60 cm if wide is > 1m It has to be 10" to 12"; Recommended 11" (25.4 to 30.48 cm; Recommended 27.94 cm) Source: https://inspectapedia.com/Stairs/Ideal-Stair-Design-Specifications.php Treads depth for winder stairs turn Winder treads shall have a minimum tread depth of 10 inches (254 mm) measured at a point 12 inches (305) mm from the side where the treads are narrower. Winder treads shall have a minimum tread depth of 6 inches (152 mm) at any point. Within any flight of stairs, the greatest winder tread depth at the 12 inch (305 mm) walk line shall not exceed the smallest by more than 3/8 inch (9.5 mm). Source: https://inspectapedia.com/Stairs/Stair_Winders.php Treads count for squared spiral "Calculation of the stairs with a pivoting steps of 90°. In my experience the best is 3 steps with a width of 80 cm. More - steps will be too narrow and so uncomfortable." Source: https://www.zhitov.com/en/lestnica3/ * * For me, at a 90° winder stairs turn, it appear too restrictive. * * Probably they have right considering the safety rules but ... * ** So, for square spiral stair I'll use the measure of walk line at 50 cm. * ** The measure have to start from pole (excluded) * ** For uniformity variation I'll use 1.0 cm. Tread hight (Step rise) For a staircase it have to be 4" to 8.25". Recommended 7" Source: https://inspectapedia.com/Stairs/Ideal-Stair-Design-Specifications.php That mean 10.16~20.955 cm. Recommended 17.78 cm * **I've used some rounded values:10.2, 17.8, 21.0 cm Tread offset (nosing) For a staircase is required! It have to be 1" to 1.1/2" projection beyond the riser face Source: https://inspectapedia.com/Stairs/Ideal-Stair-Design-Specifications.php Nosing overlaps must be at least 16mm Source: https://www.pearstairs.co.uk/staircase-buillding-regulations/ Projection: The nosing must project between 3/4 inch (19 mm) and 1 1/4 inches (32 mm). This ensures the nosing provides enough of an extended stepping surface. Source: https://www.homebuildingandrepairs.com/codes/stair/shaping_tread_nosing.html * ** I'll use 1.6~3.2 cm optimum 2.5 cm Stairs Width For a staircase wider than 1.8 m, a balustrade is required in the middle Source: https://inspectapedia.com/Stairs/Ideal-Stair-Design-Specifications.php Minimum Distance Between Two Railings — Under 30” Source: https://grecorailings.com/five-international-...ed-to-know-for-handrails/ Handrail IBC Code Requirement 1: Handrail Height — 34”- 38” 2: Handrail Diameter — 1.25” – 2” If the handrail isn’t circular, the perimeter dimension should not be less than 4 inches and mustn’t be greater than 6.25 inches. The maximum and minimum cross-sectional dimension should be 2.25 inches and 1 inch, respectively. A minimum radius of 0.01 inches is required for the edges. 3: Minimum Hand Clearance — Not Less Than 1.5” (3.81 or ~4.0 cm) 4: Maximum Projection of Railing — 4.5” (11.4 cm) “Projections into the required width of aisles, stairways, and ramps at each side shall not exceed 4.5 inches (114 mm) at or below the handrail height.” 5: Minimum Distance Between Two Railings — Under 30” Source: https://grecorailings.com/five-international-...ed-to-know-for-handrails/ * ** I'll use: 86.4 to 96.5 cm with optim 91.44 (36") Handrail 2010 ADA Standards Code Requirement 505.7.1 Circular Cross Section Handrail * shall have an outside diameter of 1.25" (32 mm) minimum and 2" (51 mm) maximum. 505.7.2 Non-Circular Cross Sections Handrail * shall have a perimeter dimension of 4" (100 mm) minimum and 6.25" (160 mm) maximum, * and a cross-section dimension of 1" (25 mm) minimum and 2.25" (57 mm) maximum. * A minimum radius of 0.01 inches is required for the edges. Source: https://up.codes/s/cross-section * ** I'll use handrail width range: 3.2 cm to 5.1 cm Balusters Regulations stipulate that a 100mm sphere should not be able to pass through any openings between spindles or any other gaps in the handrail, such as between glass panels. This is to prevent small children from getting their head stuck. Source: https://www.pearstairs.co.uk/staircase-buillding-regulations/ Pitch: optimal 7"/11"(Angle: 32.5° or Slope: 64%) Staircase category according to angle range (from 0° to 90°) or to slope range (from 0% to 380%): -ramps: angle: 0° to 18°; Preferred: 0° to 7°; slope: 0% to 32%; Preferred: 0% to 12% -stairs: angle: 18° to 50°; Preferred: 30° to 37°; Optimal: 32° to 33°; Ideally: 32.5° slope: 32% to 102%; Preferred: 58% to 75%; Optimal: 64% -ladders: angle: 50° to 90°; slope: 102% to N/A ---stepladders & raised fixed ladders: angle: 50° to 75°; slope: 102% to 373% ---ladder with rungs: angle: 75° to 90°; slope: 373% to N/A Formula: (Rise / Run ) x 100 = % Slope Source: https://inspectapedia.com/Stairs/Ideal-Stair-Design-Specifications.php Job verdict using angle and comfort Dmitry Zhitov: „The length of the pitch man is 60 to 66 cm, on average - 63 cm. Comfortable stairs corresponds to the formula: 2 step height + depth level = 63±3 cm.” Source: https://www.zhitov.com/en/lestnica3/ Francois Blondel formula: g + 2r = 24 inches (60.96 cm so, 61 cm) 24 inches is 610mm, roughly in the middle of the 550mm to 700mm (21³/₄" to 27¹/₂") Source: https://www.practicalarchitecture.com/blog/th...f-a-comfortable-staircase * ** I'll use 55 to 70 cm for Stride length A new beta version . Probably this will be the final look even I'm not very satisfied. I've tried to implement the above set of rules. Some of them not yet. Not fully functional and many calculus could be false. Try it with care!! I'm interested on how it work under MacOS. I don't have the possibility to test. Few pictures: ![]() ![]() ![]() ![]() ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Keet at Feb 10, 2025, 9:30:28 PM |
Re: Stair builder Great work with this new version of the staircase generator! Tread offset (nosing) It differs per country. Instead of a nose you can have a sloping riser to get a thread offset.For a staircase is required! Staircase regulations differ per country. When you create a staircase you should check the requirements for the location of your project. Most will be very close or the same as the numbers you listed but there are subtle differences. Public staircases are different Staircases in public buildings have different and extra requirements. Sometimes no nose or only a very small one is allowed. Most building codes require a non-slip surface at the top/front of the threads and some codes require it to be in a contrasting color. In most cases this is a rubber or plastic L-strip at the top/front of the thread. A sloping riser allows for a deep enough thread offset without the need for a 'real' nose. Some building codes have the requirement for intermediate landings at specific heights/#steps for long staircases. In most cases handrails on both sides are required and not optional and they have to extend beyond the first and last step. A public staircase has a larger minimum width requirement to allow safe two-way traffic and some countries require a center handrail for wide staircases. When you create a staircase for a public building you should definitely check the local building codes because they can differ very much between countries. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by dorin at Feb 11, 2025, 1:09:30 PM |
Re: Stair builder Thanks Keet! 1. About nosing: The plugin let user set it at 0 and ignore the recommendations. I knew that could be at a slope angle but it is difficult to make programmatically at least on the current approach. 2. On my research I've seen the regulations for public stairs and I've limited the plugin purpose to domestic use. For public stairs your library it is more performant. 3. I've tried to improve the cut out shape to meet head room and handrails requirements. Unfortunately, I think I've ruin most of the situations. There is more to work (and math to learn). 4. Not all the controllers are functional at this moment(like middle steps). I've add it to make room for it on UI but I don't know (yet) how to implement it. 5. There is many things TODO, to verify and correct it. 6. After I'll implement the middle steps count I'll continue with custom cut out shape for U_SHAPE varints. 7. My intention wasn't to generate "good looking" stairs but correct stairs. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Keet at Feb 11, 2025, 2:20:15 PM |
Re: Stair builder 2. On my research I've seen the regulations for public stairs and I've limited the plugin purpose to domestic use. Very understandable. A public staircase can have some pretty different requirements that are hard to implement for generic, domestic staircases. I just added the info for those who want to create a public staircase and find out that the stair builder is for domestic staircases.About the cutout shapes: Creating the cutout itself is not that difficult, but it's very difficult to determine what the points of the staircase are that you should use for the cutout. So I understand the trouble you have with these cutouts! You might want to check out the L parameter for cutouts. It draws a line from the last point to the absolute L coordinate. That might be easier for creating weird cutouts. As you know I work a lot with dodecagon shapes and a cutout for such a shape looks like this: M0,0.366022099 v0.267955801 L0.133977901,0.866022099 L0.366022099,1 h0.267955801 L0.866022099,0.866022099 L1,0.633977901 v-0.267955801 L0.866022099,0.133977901 L0.633977901,0 h-0.267955801 L0.133977901,0.133977901 zI assume you already have the SVGPathMiniManualForSweetHome3D, otherwise you can download it here: Guide for SVG Path cut-outs and other furniture properties (PDF) by OKH or from the manuals section on dodecagon.nl. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Xlance at Feb 25, 2025, 1:10:16 PM |
Re: Stair builder Excellent Work Sir:-) Here are some ideas for (Beta 5) https://imgur.com/a/JxuGjnj & https://imgur.com/a/b6tn0jG Thank You ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
| Posted by dorin at Feb 25, 2025, 7:31:07 PM |
Re: Stair builder Thank you Sir for your appreciations! 1. I've seen your contributions at Staircase generator. 2. Some of your suggestions are valuable and I will think about them for the likely version 1.1: 2.1. Different shapes sections for balusters. 2.2. Panels between balusters. 3. All of this will imply changes in UI and I don't know yet how it work this beta4 especially under MacOS. Many thanks again and we will see! ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Keet at Feb 25, 2025, 9:24:37 PM |
Re: Stair builder Just an idea... Instead of having a field with step rise and number of steps why not have a field to set the room height+floor thickness that the staircase has to span. From that height the number of steps and step-rise can be calculated to get as close to the optimum 17.8 as possible. Just display the calculated step height (riser height+thread thickness). When you create a staircase that is actually what you try to do: create a number of steps with an optimum height to get to the top of the room. You have to make small adjustments to the step height and the number of steps and see that you get to the room height. It is much easier to calculate this because a calculation is not limited to 1mm increments. That limit sometimes makes it impossible to get exactly to the correct height where a calculation does not have that problem. An obj file can store multiple numbers after the decimal point. Or have a button that does that calculation and sets the height numbers as calculated. Even if the displayed numbers are rounded the calculated numbers can be used for generating the staircase. Why is this important? Normally I would say to get as close as possible and if you are 1cm short just generate and increase the height of the generated staircase with 1 cm. But that doesn't work with a staircase because a staircase has balusters and handrails making the total height of the object more than the room height. You can't just add 1cm. You have to put a camera at the top of the stairs and make small changes to height until the top thread evens out with the floor. That's what I did until I started custom creating my staircases. Users of the staircase generator will be very happy if the steps add up to the exact needed height. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by hansmex at Feb 25, 2025, 10:53:33 PM |
Re: Stair builder @Keet - excellent suggestion @Xlance and Dorin - panels are great suggestion (please, please) ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Keet at Feb 26, 2025, 6:47:07 AM |
Re: Stair builder @Xlance and Dorin - panels are great suggestion (please, please) Agree! No panels was one of the main reasons I started creating custom staircases. I never liked the thin balusters of the staircases, because I often create staircases for large, public buildings that rarely have such balusters. You will have to find a way to allow selecting the number of panels above each other and its (individual?) height. Maybe from one full panel to max 3 or 4 panels. I bet the panels will be more popular than the cylinder balusters.---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Daniels118 at Feb 27, 2025, 7:41:04 PM |
Re: Stair builder @Dorin don't forget to publish your plugin on sourceforge if you want it included in the Plugin Manager! |
| Posted by dorin at Mar 1, 2025, 7:10:50 PM |
Re: Stair builder Of course but when the time will come. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by dorin at Mar 10, 2025, 7:09:13 PM |
Re: Stair builder Probably it's time. First stable (probably) release: Stair Builder v.1.0 and a test file . I'll let you to discover it. Also on Source Forge ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by dorin at Mar 11, 2025, 1:29:55 PM |
Re: Stair builder Errata: While only today I've have a feedback from a macOS user you need to install this or this updated version. I'm sorry for the inconvenience. It have to look something like this: ![]() ![]() ![]() ![]() ![]() @Keet & not only On the right last row I've insert information's related to the next level(if exist). At start, the plugin verify this and set the calculated thickness. Modifying the steps number, the next level indicator will warn you. When next level: 0 cm you have to be sure the last tread it is at the same elevation as upper room. Try with the test file I've provided. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by beji at Dec 3, 2025, 1:10:27 AM |
Re: Stair builder Hi Dorin Great work on this staircase generator! In my area, houses typically use the space under the staircase as a storage room. If you donât mind, would you be interested in adding a new feature like the one shown in image B - something like a concrete enclosure to close off the underside of the stairs? This would make it easier for us to build a sloping wall, as shown in image C. https://drive.google.com/file/d/1NOP7Bv8uqcxHSOYH6B1pssXvhaxr9nSy/view By the way, thank you so much for your contribution. |
| Posted by dorin at Dec 4, 2025, 5:28:08 PM |
Re: Stair builder Thanks! In general, there are three types of stairs classified according to the construction material: wood, metal, and concrete. This is for wood, and you want something for concrete or a combination. It is a good idea to make some adjustments for this request. It's not simple, because it has to work for all types of shapes. I'll try to do it, but I don't know when. Right now, I'm working on another plugin that's putting up a lot of resistance to my one and only neuron. Thanks again. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by dorin at Dec 7, 2025, 6:12:04 PM |
Re: Stair builder @k005 About your suggestion made here . It's a good idea! I think will be possible in the future like is for Roof Generator. With good and bad. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 23, 2026, 9:52:52 PM |
