Print at Oct 3, 2026, 5:52:00 PM
Posted by tdanielson at Nov 17, 2024, 3:53:17 PM
Splash Pad model for outdoor yard
Apologies if this double posted, I don't see the 1st. I am working on my first project, a dog day care. I want to put a splash pad in the outside play yard but have not been able to find a 3D model of one so far, but maybe my inexperience is the cause. Could someone point me to any free models of a splash pad that I could use? Or if not, are there any kind hearted artists who wouldn't mind making a simple one? Sincere thanks.
Posted by Keet at Nov 18, 2024, 10:07:16 AM
Re: Splash Pad model for outdoor yard
A splash pad is a pretty simple model but there are so many different types/sizes/designs that you will have to be a little more specific in what you are looking for. Post an image of what you want it to look like and I'll see what I can come up with.
Posted by tdanielson at Nov 20, 2024, 6:52:34 AM
Thank you for the reply. I was thinking something like:
http://aquaplaydirect.com/image/99254643.png
Posted by hansmex at Nov 20, 2024, 10:41:03 AM
file
Posted by Keet at Nov 20, 2024, 11:38:08 AM
I think Hans found the same fountain to use smile
Image: https://www.mediafire.com/view/4qqfct70z47e42h/DogSplashPad.png/file
Model: https://www.mediafire.com/file/i6md294q5u5xijj/DogSplashPad.zip/file
Project: https://www.mediafire.com/file/7u0zz3ezueuw4m2/DogSplashPadProject.zip/file
Posted by GaudiGalopin3324 at Nov 20, 2024, 12:25:50 PM
Hi. This rug can be made by yourself. You need to find a picture of the "dog's footprint in a circle" in the search. Make it a background image on the plan, set the size of the circle, for example, 300 cm.Then you need to start making a room based on this drawing. Start from point 1, go to point 2, carefully outline the area through small distances to point 3, go to point 4, outline everything around the perimeter and return to point 3, outline to point 5, then to 6 and so on. The main thing is not to be afraid!!))) And don't stop. The most recent action is to complete the outer circle, reach point 1 and double-click. The room is ready! It will take about 15 minutes with moderate care. The neater the longer))
when creating a room, you need to turn off the magnet. Then you need to turn this room into a rug with a thickness of for example 3 cm. You need to set the overlap thickness of 3cm in the settings and create a new level, you will get a 3cm thick mat. You need to import this room into OBJ, then export it back as a model and give it a name, assign a color or texture. Add dogs, fountains. Try to do it yourself, it's very exciting. And most importantly, you will be able to get exactly what you need.
blushing
Posted by GaudiGalopin3324 at Nov 20, 2024, 12:32:33 PM
file here
Posted by tdanielson at Nov 21, 2024, 5:09:02 AM
Wow! I am very impressed with the models and the willingness of this community to assist with a project. Thank you all very much! I will incorporate into a design that I intend to present to a county planning department. Hopefully I will one day post the completed real life project. Thank you all again!
