Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Bug? No lightSourceMaterialName when Door or window |
| Print at Oct 1, 2026, 1:16:44 AM | |
| Posted by Keet at Nov 18, 2024, 12:19:41 PM |
Bug? No lightSourceMaterialName when Door or window I ran into an unexpected problem with a window where I wanted to assign the lightSourceMaterialName property to a part of a window. The problem is simple: you can't set the property in the Furniture Library Editor when the object is a Door or window. I tried to cheat by manually adding the lightSourceMaterialName property in the library properties file but of course that didn't work. I can't think of any logical reason why this shouldn't work for a window. For a staircase it does work. I tried it, the library property is available and there's a power property when you modify the staircase. A lighted side panel looks good in a render! Is there a reason why this doesn't work for a window or is this a bug? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Nov 18, 2024, 12:54:45 PM |
Re: Bug? No lightSourceMaterialName when Door or window Sorry, it’s probably a misconception from me. HomeLight and HomeDoorOrWindow classes are subclasses of HomePieceOfFurniture with no link between them, whereas light should have probably been a property of HomePieceOfFurniture. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Keet at Nov 18, 2024, 1:00:33 PM |
Re: Bug? No lightSourceMaterialName when Door or window If I read that right there's no chance of a fix without breaking backward compatibility? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 1, 2026, 1:16:44 AM |
