Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to rotate a whole map from vertical to horizontal |
| Print at Oct 2, 2026, 5:37:49 PM | |
| Posted by Fred19732 at Jan 22, 2025, 9:47:44 AM |
How to rotate a whole map from vertical to horizontalHi everybody, I built a house plan in a vertical position. My question is : how can I do to rotate the whole map from vertical to horizontal without having to rotate each object of the map? many thanks for your answers |
| Posted by MarioSambol at Jan 22, 2025, 7:53:56 PM |
Re: How to rotate a whole map from vertical to horizontal Select all the objects, then group them. Now you can rotate everything in the group at once. |
| Posted by Daniels118 at Jan 24, 2025, 7:56:00 PM |
Re: How to rotate a whole map from vertical to horizontal Unfortunately not all object types can be grouped. Luckily there are 2 plugins that can do this work: - Advanced plan editing plugin - Home rotator plugin I encourage to try both of them, the first is more complete, but the second should be a lot easier to use for your use case. |
Current timezone is GMT Oct 2, 2026, 5:37:49 PM |
