Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: SurroundRoom Plugin |
| Print at Sep 23, 2026, 6:26:21 PM |
| Posted by Ollie_Jess at Feb 19, 2025, 11:07:36 PM |
SurroundRoom Plugin Hello SH3D community! I developed a plugin that surrounds a room with a piece of furniture, externally or internally, in 3 different ways. Both the room and the furniture must be selected at the same time on the plan. This is the direct download and is also on SourceForge (please download the version 1.1 instead of 1.0, due to compatibility problems). These are the steps for surround a room with the plugin: Step 1.- Select the object and the room. Step 2.- Select “Tools” in the principal menu and select “Surround room…” Step 3.- Customize the way in which the room will be surrounded. Result: ![]() ---------------------------------------------------------------------- This is another example using the plugin: Step 3.- Select “Surround internally” Result: Hope you like the plugin! |
| Posted by Keet at Feb 20, 2025, 9:22:54 AM |
Re: SurroundRoom Plugin Nice! Does it also work with an room created from curved walls? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by dorin at Feb 20, 2025, 12:46:52 PM |
Re: SurroundRoom Plugin @Ollie It's a good start! Keep going! @Keet I've test it and NO, not this time. Maybe in the future. @Me While this plugin act as a multiplier what if it will be added as feature to the current Multiplier? Could be BUT not before to have a more performant (customizable) polyline in the main program. What's in my mind: The Art Off Illusion (java) have the option to draw objects (or extrude) along a curved line especially to make pipes. Could be a good source of inspiration. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by JonnyD at Feb 20, 2025, 1:58:13 PM |
Re: SurroundRoom Plugin I’m afraid the plugin just presents a warning that no room is selected for me - even when it is. |
| Posted by dorin at Feb 20, 2025, 7:18:43 PM |
Re: SurroundRoom Plugin @Ollie JonnyD is right, but don't despair. I've encountered the same problem at the beginning and Emmanuel have helped me. Now it's my turn. You have to verify first if the home have more levels. Study of case: Level selectedLevel = getHome().getSelectedLevel();-New file; draw a room; add an flower and select both. Run the plugin => OK. selectedLevel = null-On the same file add a level and then delete it. selectedLevel != nullSo, in my Select/Hide Special plugin I've use something like this: if (selectedLevel == null || selectedLevel.isVisible()) {Feel free to take inspiration from other plugin sources. I do it all the time. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Ollie_Jess at Feb 21, 2025, 12:07:29 AM |
Re: SurroundRoom Plugin @dorin thanks for detecting the source of the error and for recommending a way to fix it. I also detected that if the furniture angle is not at 0° it doesn't surround the room well. In version 1.2 these problems will be solved, which I hope to finish this month. In version 1.3 I will add more ways to surround rooms, being able to surround curved lines and more customization to surround rooms. |
| Posted by Ollie_Jess at Feb 26, 2025, 4:14:31 AM |
Re: SurroundRoom Plugin Hello community! the version 1.2 is ready, with the problems mentioned fixed. If there is something wrong with the plugin or you have any suggestions, let me know. |
| Posted by Ollie_Jess at Feb 26, 2025, 4:18:03 AM |
Re: SurroundRoom Plugin This is the version 1.2 and is also on SourceForge |
| Posted by Daniels118 at Feb 27, 2025, 7:26:42 PM |
Re: SurroundRoom Plugin Nice plugin! I've added it to the Plugin Manager catalog! |
| Posted by Ollie_Jess at Feb 27, 2025, 9:58:02 PM |
Re: SurroundRoom Plugin Thanks Daniels118! |
Current timezone is GMT Sep 23, 2026, 6:26:21 PM |
