Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Export Plan Image v1.1 |
| Print at Oct 9, 2026, 8:33:19 PM |
| Posted by Keet at Mar 2, 2025, 9:50:14 PM |
Re: Export Plan Image v1.1 Here is a little gadget. A very small Metric<>Imperial Calculator in html/css/javascript. You can run it local without internet connection. With html/css/javascript you have all the source code which allows you to change it every way you like. Metric<>Imperial Calculator When you have set Imperial as your Sweet Home 3D preference and you import a model or add it from the catalog: make sure you have magnetism off. After import you can switch magnetism on again. If you import with magnetism on then Sweet Home 3D does an automatic conversion to imperial which changes the original dimensions of the model. (obj files contain metric numbers.) This can cause problems with aligning multiple models from a series. This happened with a member that works with imperial and encountered strange alignment problems with my kitchen models. Dragging the models from the catalog with magnetism off solved the problem. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Xlance at Mar 5, 2025, 2:20:58 AM |
Re: Export Plan Image v1.1 😀 inch and cm are both there for everyone preference 😀 ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
| Posted by MarioSambol at Mar 7, 2025, 12:47:58 AM |
Re: Export Plan Image v1.1 I'll try the plugin and comment afterwards. I think it's good to have something like that rather than taking screenshots. The measurement system itself isn't that important, although I mostly use metric, and very rarely imperial. |
| Posted by Xlance at Mar 8, 2025, 1:29:40 AM |
Re: Export Plan Image v1.1 @MarioSambol I have 2 Big plugins in the making ;-) https://imgur.com/a/NESWhib Preview for 3D Parametric Generator https://www.mediafire.com/folder/m09sbl6x54sju/Preview ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
| Posted by Xlance at Mar 17, 2025, 7:09:15 PM |
Re: Export Plan Image v1.1 After some back and forth discussions with the community (Thanks Olivier), here is version 1.1d - Several testing mechanisms specific for Mac OS - *.png Export now working on Mac OS - Fixed an issue with Euro digital separator (,) - Ensured .png or .jpg is appended to the file name regardless of the platform https://www.mediafire.com/file/rdxftm4jcyikfpc/ExportPlanImage-1.1d.sh3p/file ---------------------------------------- Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins |
Current timezone is GMT Oct 9, 2026, 8:33:19 PM |
