Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: SweetHome3D freezes all the time |
| Print at Sep 26, 2026, 12:18:27 PM | |
| Posted by shyne at Mar 9, 2025, 4:27:17 AM |
SweetHome3D freezes all the time Apple M1 Pro + Sweet Home 7.5 I have to force it to quit because it starts to slow down after a time and freezes / hangs Is there any known solution for that? I hoped an update would help but it does not. Plugins: https://ibb.co/21N5ZDJc I did not have this issue at the beginning as far as I remember. My project is rather large. |
| Posted by Daniels118 at Mar 9, 2025, 5:10:14 PM |
Re: SweetHome3D freezes all the time Try to get the console output, check from time to time to see if there are errors and post it here. To get the console output run the program from a terminal (this should be enough on Mac, but if you don't get any message try to redirect the output to a file as described here: https://www.sweethome3d.com/support/forum/viewthread_thread,9906#46437 ) |
| Posted by YGYL at Mar 11, 2025, 1:45:34 AM |
Re: SweetHome3D freezes all the time You said your project is quite large and then it gets stuck. Then I have experience~ Generally speaking, projects that are too large and complex and have too many objects will experience this problem. One of the most likely reasons is that you have turned on :Top view in plan objects and :Floor color or texture in plan room rendering. Change Furniture icons in plan to Catalog icons. Change Room rendering in plan: to Monochrome |
| Posted by Puybaret at Mar 11, 2025, 10:53:58 AM |
Re: SweetHome3D freezes all the time Try to increase max memory as explained in the FAQ. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 12:18:27 PM |
