Print at Sep 24, 2026, 4:33:20 PM
Posts: 18   Pages: 2   [ Previous Page | 1 2 ]
Posted by Xlance at Apr 5, 2025, 12:26:02 PM
smile   Camera Data Generator v1.1n Fixed
https://www.mediafire.com/file/q2xtxy3wmfeu8il/CamDataGenerator-1.1n.jar/file
Enjoy
Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins
Posted by dorin at Apr 5, 2025, 5:17:12 PM
Re: Camera Data Generator v1.1n Fixed
Now it works OK.
The calendar AND the csv output.
Problem:
I steel receive some errors:
java.lang.ClassNotFoundException: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
at AdvancedCameraDataGenerator.<init>(AdvancedCameraDataGenerator.java:148)
Probably you could find a better solution.
Like to find first what LaF are provided by the local OS.
Posted by Xlance at Apr 6, 2025, 3:09:16 AM
Camera Data Generator v1.1p
Hello :-)
+ Added a multi stage Fallback Mechanism for selecting look and feel of the UI, the program will:
Check first if OS is Mac or not,
if yes > apply MacOS LookAndFeel
if not > will detect installed LookAndFeels > apply system default
if failed > apply Cross Platform LookAndFeel
if failed > apply Metal LookAndFeel
+ Added junit.jar which was missing
https://www.mediafire.com/file/mycx02vmdqimt8i/CamDataGenerator-1.1p.jar/file
Cheers
Posted by dorin at Apr 6, 2025, 6:46:35 AM
Re: Camera Data Generator v1.1p
Now it appear to works correctly. applause
I think this could be the final 1.1.
One more suggestion (but not mandatory):
When click OK -> close (exit) the application.
You've made a very good job!
PS (also not mandatory)
You could put cityCoordinates and timeZoneOffsets in two text files and loaded from there.
In this way the main program will be more easy to read.
Posted by Xlance at Apr 6, 2025, 10:19:00 AM
Export CAD to SH3D
@Dorin and Everyone
Take a look at this brand new plugin :-)
https://sourceforge.net/p/sweethome3d/plug-ins/56/
Posted by z56oo at Apr 7, 2025, 5:53:54 PM
It appears on the generation of an elliptical path that for the intermediate points there is an inaccuracy between the position of the point and the given Fov
Posted by z56oo at Apr 7, 2025, 6:01:33 PM
Sorry replace in my previous message Fov by Yaw
Posted by Xlance at Apr 8, 2025, 3:58:00 AM
Camera Data Generator v1.1Q
Hello smile
Added a new function / checkbox to switch CSV separator from ( , ) to ( ; ) for Euro OS
Note:
CameraBagPlugin-1.8 plugin now supports importing CSV files with ( ; ) separator
https://sourceforge.net/p/sweethome3d/plug-in...CamDataGenerator-1.1Q.jar
