Print at Sep 23, 2026, 9:53:11 PM
Posted by jscheller at Mar 22, 2025, 11:10:52 AM
Arm64 Ubuntu 24.10 blacked out parts of the window
Hi everyone,
I just installed sweethome3d from the ubuntu repositories on an Elitebook G1Q with a Snapdragon X with apt install sweethome3d and whenever I launch the application parts of the window are blacked out.
Terminal output is:
WARNING: A restricted method in java.lang.System has been called
WARNING: java.lang.System::loadLibrary has been called by javax.media.j3d.NativePipeline$1 in an unnamed module (file:/usr/share/java/j3dcore-1.5.2.jar)
WARNING: Use --enable-native-access=ALL-UNNAMED to avoid a warning for callers in this module
WARNING: Restricted methods will be blocked in a future release unless native access is enabled
Java 3D: implicit antialiasing enabled
any idea why this is happening and how to fix it?
Thanks in advance
J
