Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: flip/mirror a plan? |
| Print at Oct 2, 2026, 1:12:53 AM | |
| Posted by MarcInBKK at May 18, 2025, 3:48:01 PM |
flip/mirror a plan? I went through all the work of creating a great plan, but the land we found requires me to "flip/mirror" the plan. left to right. I can't seem to find a way to do this. Hopefully someone here has some ideas. |
| Posted by Keet at May 19, 2025, 12:48:03 PM |
Re: flip/mirror a plan? Ctrl-A, right click, Flip horizontally. You will have to do that for each level. The best way is to make each level the only one visible to flip everything on that level. This doesn't always work 100% but you will have most of it and can manually adjust the rest. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by hansmex at May 19, 2025, 4:40:11 PM |
Re: flip/mirror a plan? or use the AdvancedEdit plugin ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by MarcInBKK at May 19, 2025, 5:08:02 PM |
Re: flip/mirror a plan? Ctrl-A, right click, Flip horizontally. You will have to do that for each level. The best way is to make each level the only one visible to flip everything on that level. This doesn't always work 100% but you will have most of it and can manually adjust the rest. Excellent, thank you! |
| Posted by Keet at May 19, 2025, 5:42:11 PM |
Re: flip/mirror a plan? or use the AdvancedEdit plugin Now that I think about it, aren't the Flip functions from the Advanced Edit plugin?---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 1:12:53 AM |
