Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Set a default polyline for color, size arrow, shape, etc. ?? |
| Print at Oct 3, 2026, 1:57:30 AM | |
| Posted by srfoot at Aug 9, 2025, 3:49:06 PM |
Set a default polyline for color, size arrow, shape, etc. ?? Hi; Is there a way to set a polyline default for a project? I want to use the same size, shape, arrow design, color, etc. for a polyline without having to go back each time I draw one and choose all these options many times. I have not been able to find a way to make this a default. Thank you! |
| Posted by Keet at Aug 10, 2025, 12:56:11 PM |
Re: Set a default polyline for color, size arrow, shape, etc. ?? Unfortunately that is not possible. A work-around is setting the properties for the first polyline and copy/paste it for the next. With copy/paste all changes on the original are copied too. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by srfoot at Aug 10, 2025, 1:51:17 PM |
Re: Set a default polyline for color, size arrow, shape, etc. ?? Hi. I found a work around. I used the default polyline to make many in each room. Then, in each room, I clicked on one polyline and then pressed ctrl-A to highlight all of them, I picked the modify polyline option and when the polyline window popped up, I chose the styles/size/color I wanted then clicked ok and all polylines changed to the new choice. Thank you for your time and giving me forum access. |
Current timezone is GMT Oct 3, 2026, 1:57:30 AM |
