Print at Sep 26, 2026, 5:42:44 PM
Posted by hansmex at Mar 31, 2010, 4:33:59 PM
Ubuntu: where is .eteks directory ??
Emmanuel:
Recently I newly installed Ubuntu (Lucid 11.04 beta) on my PC. I made a backup of all files, including the .eteks directory, so that I could exchange it after setting up SH3D.
After installing SH3D 2.3 I cannot find the .eteks directory anymore, and I'm left with just standard libraries that come with the install.
I would like to re-install all my imported models and textures... Can you help?
Posted by Puybaret at Mar 31, 2010, 7:32:09 PM
Re: Ubuntu: where is .eteks directory ??
The Linux .eteks directory is created only if required. The easiest way to create it is probably to import a dummy piece of furniture in your catalog and then delete it.
Note that if you want to transfer your library, you'll also have to copy the .java/.userPrefs/com/eteks directory (I hope you made a backup of that directory).
