Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Floor texture |
| Print at Sep 30, 2026, 9:57:49 PM | |
| Posted by RUSSIAN at Apr 1, 2010, 7:17:24 AM |
Floor texture Now the room's floor texture isn't connected to the room's position, am i right? It's connected to All-Plan-Zero-Point? Or it's possible to connect it to the room? It would be nice to do it, because it would give us a possibility to made a custom textures, that would fit the room. thnx. |
| Posted by Puybaret at Apr 1, 2010, 12:51:22 PM |
Re: Floor texture You're right, all the textures mapped on rooms floor and ceiling are connected at the origin of the plan (as the ground texture too). I understand your needs but it would be useful only for rectangular rooms parallel to x and y axis. If you really need this feature, I suggest you use version 2.3 and map a texture on a thin box that you'll spread on the floor. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 9:57:49 PM |
