Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: please help me |
| Print at Sep 27, 2026, 8:22:27 PM | |
| Posted by sara11 at Apr 8, 2010, 5:12:38 PM |
please help me Hi every body ... when I creat photo and choose best.. It takes long time then It does not apear What is proplem ?? I have windowes system and version is 2.3 Thanks ,, ![]() |
| Posted by Puybaret at Apr 8, 2010, 5:34:33 PM |
Re: please help me Maybe you put too many items in your home. In a new document, add just one piece of furniture and check if you can create a photo of it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sara11 at Apr 9, 2010, 1:05:27 AM |
Re: please help me Puybaret Thank you very much ,, It is o.k now ... |
| Posted by Puybaret at Apr 9, 2010, 7:02:43 AM |
Re: please help me So what was the problem? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sara11 at Apr 11, 2010, 12:30:34 AM |
Re: please help me It was I can not creat photo only on fast ... but best Ican not specally when big size project ... I can creat best photo only in samall project ... I need creat best photo for big project ... Is there any solution for this proplem ... It is big proplem for me .. I hope to excuse me to bad my languge ... Thanks Puybaret Sara ,, |
| Posted by Puybaret at Apr 11, 2010, 11:01:16 AM |
Re: please help me It might be a memory size problem. To increase memory size used by Sweet Home 3D up to 1024 MB, use the version with an installer, create a text file named SweetHome3D.l4j.ini in the same directory as SweetHome3D.exe, and write the following text in that file: -Xmx1024mand relaunch Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Apr 11, 2010, 12:02:33 PM |
Re: please help me Emmanuel: Would it be possible to include this as an option in Preferences ? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Apr 11, 2010, 5:17:03 PM |
Re: please help me That's a nice idea, but changing the maximum memory size used by Sweet Home 3D can't be done so easily. You have to change the -Xmx option in launch scripts: in some cases (like with Java Web Start and applets) that's simply not possible, and in other cases requesting too much memory could simply prevent Sweet Home 3D from launching. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sara11 at Apr 11, 2010, 11:40:03 PM |
Re: please help me Puybaret your suggestion is good ... Now , I can cerat photo even in big project ... I have another proplem with imprt furniture some picture in http://www.model3d.biz/obj/?did=21 when I import them .. they are becam scattered and gray colour Do you have any solution for this proplem ??? Puybaret ,, Thanks alot for help me .. |
| Posted by hansmex at Apr 12, 2010, 12:04:56 AM |
Re: please help me Sara: Think of OBJ as a language to describe a 3D model. As with real languages, there are plenty of dialects. Unfortunately not all dialects are the same. This can lead to incompatibilities when you try to import an OBJ model in SH3D. Sometimes a workaround may help. Import the model in Blender , Misfit 3D or in Art Of Illusion . Then save or export the model again. There is no guarantee, but sometimes this solves the problem. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by sara11 at Apr 12, 2010, 12:54:43 PM |
Re: please help me I well try ,,, Hans ,, thanks |
Current timezone is GMT Sep 27, 2026, 8:22:27 PM |
