Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Areal View Problem |
| Print at Aug 25, 2026, 12:17:23 AM |
| Posted by Keet at Dec 2, 2025, 1:34:28 PM |
Re: Areal View Problem I'm sorry, but then I am out of ideas what could cause this problem. You could check that all preference settings are same on both machines but I assume you already did that. Still, you should check with another project if the same problem occurs. If it does than the only thing left is the different machines/installed distributions. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Daniels118 at Dec 2, 2025, 5:33:47 PM |
Re: Areal View Problem Are you able to zoom in/out using W/S keys or Up/Down arrow keys? Some mouse have an high frequency scroll wheel which may affect the scroll speed, so trying with a different mouse could help. Another option is, with Pan3dView plugin installed, go to View 3D -> Pan 3D view settings..., then uncheck the "Exponential scroll" option. This should enable the default zoom speed. If nothing works, run the program from the command line, copy the output and paste it here (if there are java exception we may find the root cause). |
| Posted by Swelst at Dec 2, 2025, 8:20:50 PM |
Re: Areal View Problem I have Pan3dView.sh3p in the plugins Folder. I din't find any option to change any pan3d setting. Running from command line is not an option since this is a flatpak installation, as it is the same like on the Desktop PC |
| Posted by Keet at Dec 2, 2025, 8:41:21 PM |
Re: Areal View Problem Running from command line is not an option since this is a flatpak installation And there might be the cause of your problem. Don't use a flatpak installation. The creators of flatpaks seem to think they know better what to pack and most likely have stripped the java runtime. That it works at all on your desktop is plain luck.Download the 7.5 .tgz and extract it in a directory of your choice. Start Sweet Home 3D with the SweetHome3D_Java3D-1_5_2 script. The .tgz comes with the correct Java runtime included and using that avoids all kinds of problems. It doesn't interfere with an existing Java install. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Swelst at Dec 3, 2025, 7:03:13 AM |
Re: Areal View Problem For sure that is not the problem. I installed the stand-alone version on my Laptop first. As I recognized the problem, I looked on my desktop and found that the installation there was flatpak. So I did the exact configuration with flatpak on the laptop and the problem persists. |
| Posted by Keet at Dec 3, 2025, 8:24:27 AM |
Re: Areal View Problem Check the menu > Help > About. The dialog will show the Java version that is used. Compare them between the desktop and laptop. Your best bet is using the Java version provided with Sweet Home 3D, both for the 3D display and photo rendering. (Use the SweetHome3D_Java3D-1_5_2 script from the .tgz download for an example.) ETA: I tried Sweet Home 3D with the latest Java (1.8.0_471/jre8U471) and everything seems to work fine. I needed that to fix an issue with the pluginmanager that now works as it should. Also no problems with zooming in 3D view. You can try that too. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Daniels118 at Dec 3, 2025, 7:07:38 PM |
Re: Areal View Problem Also, having Pan3dView plugin without the additional options could mean that you have an old version of the plugin, which could have bugs. |
| Posted by Swelst at Dec 4, 2025, 9:02:54 AM |
Re: Areal View Problem Java the same in both installations. Java 1.8.0.202_64bit Java3D 1,6 2a JOGL 2.5.0 Pan3d was an old Version ... new Verion (3.7.4) installed, but the behaviour, that changing angle bounces the view back to panorama persists ... |
| Posted by sjb007 at Dec 4, 2025, 2:48:56 PM |
Re: Areal View Problem A few random thoughts:
For X you could try something like xinput listâ¡ Virtual core pointer id=2 [master pointer (3)]xinput disable 18I don't use Wayland, so you would have to figure that out yourself. |
| Posted by sjb007 at Dec 4, 2025, 10:19:40 PM |
Re: Areal View Problem A few additional thoughts
Current timezone is GMT Aug 25, 2026, 12:17:23 AM |
