Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SH3D kinda makes a no-crash |
| Print at Sep 27, 2026, 9:27:39 PM | |
| Posted by hansmex at Apr 13, 2010, 11:14:33 PM |
SH3D kinda makes a no-crash Emmanuel: Under Ubuntu 10.04 SH3D v2.3 (the jnlp-version) behaves a bit strange these last days (weeks). When I open the program and draw a wall, everything is fine. I can insert a door or window, I can insert furniture. But when I am not active for a few minutes, "half" of the program freezes. I still can draw walls and rotate the 3D view, but it's impossible to insert any further furniture. Maybe there is a solution? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Apr 15, 2010, 8:18:31 AM |
Re: SH3D kinda makes a no-crash Would you have a stack trace in the Java console window? To display the Java console window: - run "javaws -viewer" command which opens two windows, - close Java cache viewer window, - click on the Advanced tab in the Java control panel window, - select Show console in Parameters > Java console, - click on OK, - relaunch Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Apr 15, 2010, 12:35:45 PM |
Re: SH3D kinda makes a no-crash Emmanuel: After opening a terminal, I executed the command you gave. The results are different from what you tell me. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Apr 15, 2010, 1:19:26 PM |
Re: SH3D kinda makes a no-crash I guess you don't use Sun JVM. What is the answer to the command "java -version"? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Apr 15, 2010, 4:09:02 PM |
Re: SH3D kinda makes a no-crash Emmanuel: In the picture above you can see the terminal window with the command I typed. The second window is the ONLY response I get. As far as I can see, I have some "compatible" Java version installed. I looked on the Sun website, but it's rather complicated to install Jave from their site. I'm so clumsy that I would prefer not to follow that list of instructions, as I'm afraid of screwing things up. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Apr 15, 2010, 4:30:45 PM |
Re: SH3D kinda makes a no-crash You're right. Don't break anything! ![]() I'll find an other way... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Apr 16, 2010, 4:30:30 AM |
Re: SH3D kinda makes a no-crash Emmanuel: Last night I did some further testing. When I run SH3D-jnlp I have the problem described above: I can draw walls, but that's all. When I run SH3D-normal I don't have any problems. When I first run SH3D-normal and, while it's open, start SH3D-jnlp, than SH3D-jnlp runs normal as well. Only difference is that SH3D-jnlp runs slower. When I close both and then run SH3D-jnlp again, it behaves normal, albeit slow. If I restart my computer and then run SH3D-jnlp again, the problem returns. With SH3D-normal I'm referring to the installer-version and SH3D-jnlp is the version that installs the icon to the desktop. I hope this may help you in narrowing down the problem. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 27, 2026, 9:27:39 PM |
