Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Stairs - hight to next level |
| Print at Oct 2, 2026, 10:57:47 AM | |
| Posted by otadmin at Jan 9, 2026, 8:20:08 AM |
Stairs - hight to next level Designing a 2 story building. Working on a flight of stairs from Level 1 to Level 2. Level 1 is Wall-height 303cm, Level 2 is Floor-height 22cm. My understanding is that the stair should be 325cm high. However, the top of the stairs is only level at 330cm. Why the extra 5 cm? |
| Posted by Keet at Jan 9, 2026, 9:21:25 AM |
Re: Stairs - hight to next level Check your level elevations, that's probably where the difference comes from. If you have problems with the relations between level elevations, heights, and floor thicknesses then read my manual "Levels explained" on dodecagon.nl ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by otadmin at Jan 10, 2026, 2:49:20 AM |
Re: Stairs - hight to next level Thanks, I learned from your link that the elevation is relative to the top of the floor, not the bottom (ceiling lower level). Solved my problem. Additionally I miscalculated the number of steps! Should have been 16 but I only counted to 14. |
Current timezone is GMT Oct 2, 2026, 10:57:47 AM |
