Print at Oct 6, 2026, 8:33:51 PM
Posted by Pilch at Apr 21, 2010, 3:13:25 PM
2D stairs
Is there any way of showing in 2D some stairs as seen on typical floor plans, with the steps and an arrow pointing up them?
Thanks
Posted by hansmex at Apr 21, 2010, 4:52:49 PM
Re: 2D stairs
Pilch:
Your question isn't very clear.
1 - You can import a background image using Plan --> Import background image .
2 - You can use a picture of the desired staircase and import it as a texture. You can then apply the texture to a box with the desired dimensions.
3 - You can model the staircase in 3D (use boxes with height 0.1), and add the arrows (narrow boxes at 45 degree angles). Group your model, export and import it and you can even re-dimension it.
I hope this helps.
Posted by Pilch at Apr 29, 2010, 3:40:45 PM
Re: 2D stairs
Thanks Hans. I'm not sure these options are quite what I am after really.
I would ideally like to be able to treat an imported image as a piece of furniture and move it around. When using a texture, the texture appears in the 3D model but not the 2d model.
Something like the image in this link (if I'm allowed to post it) is basically what I would like to be able to see in 2d plan view.
http://www.express-stairs.co.uk/images/stair_plan_6.jpg
Posted by Puybaret at Apr 29, 2010, 5:16:39 PM
Re: 2D stairs
Pilch, there's a solution for your case with SH3F files since version 2.2, but this is not easy to use until I release a furniture library editor.
You should create a SH3F file that contains your pieces (you can create it from the one accompanying this message or from the furniture you imported with ExportToSH3F plug-in), edit its PluginFurnitureCatalog.properties file and add a property named planIcon# with a value equal to the path of the icon that will appear in plan.
Attachment staircase.sh3f (19232 bytes) (Download count: 830305) (SH3F example file defining the plan icon of a staircase)
Posted by Pilch at May 25, 2010, 8:58:32 AM
Re: 2D stairs
Thanks for the guidance Puybaret. I got as far as this....
... but I unfortunately don't know how to edit this file. Whereabouts is it located?
Thanks again.
Posted by Puybaret at May 25, 2010, 12:36:12 PM
Re: 2D stairs
staircase.sh3f and any SH3F file are in fact zipped files.
Replace sh3f extension by zip, unzip it, and you'll find the PluginFurnitureCatalog.properties file.
It's a text file and you can edit with any text editor.
Once finished you'll have to zip all the content of the directory again and replace the zip extension by sh3f. Caution: PluginFurnitureCatalog.properties must be at the root of the zip file, not in a subdirectory of the zipped file.
Posted by eterps at Feb 19, 2011, 12:46:11 PM
Re: 2D stairs
Puybaret,
I downloaded your staircase.sh3f example, I can modify it without any problems. However I am unable to see the image staircasePlanIcon.png in SH3D. What am I missing?
When I import staircase.sh3f is see the following:
http://i.imgur.com/WBCwQ.png
But I would like to see staircasePlanIcon.png in the 2D view (like Pilch hoped to achieve).
Thanks for your help.
Erik.
Posted by macfrog at Feb 20, 2011, 6:53:04 PM
Re: 2D stairs
Hans, Emmanuel,
i think i can guess what this is all about. There is a need for a symbol of a staircase. just like a wall is one of sh3d's primitive objects, some could need a staircase just like this.
macfrog
Posted by Puybaret at Feb 21, 2011, 5:00:21 PM
Re: 2D stairs
eterps, be sure to use the one you imported. The list may contain synonymous stairs.
Posted by beral at Mar 13, 2011, 10:29:19 PM
Re: 2D stairs
I am so pleased I found this thread, this is exactly what I am also trying to do. I only want the 2D representation as I am sketching a house layout to give to an architect who will re-draw it. I don't really understand what it is I have to do to get a 2D object showing stairs (like the image referred to in a previous posting - http://www.express-stairs.co.uk/images/stair_plan_6.jpg) onto my library. Could you explain the steps for a newbie? Thanks.
Posted by vserghi at Nov 22, 2011, 10:59:57 PM
Re: 2D stairs
I also would like to see a 2D representation showing direction. I use SW3D mainly for it 2D capabilities, the 3D part is not much interest to me. In fact I would like to see 2D images of all the furniture, but stairs would be a great start.
Any movement on this apart from hand editing files?
Vas
