Print at Oct 20, 2026, 3:44:36 PM
Posted by mikimichele82 at Jan 29, 2026, 10:46:09 PM
ESC key issue
Good morning,
I have just installed the plugin and run some tests.
The lines are drawn correctly on the 3D view, but if I press the ESC key while the plugin is active, I can no longer draw any dimensions and I can’t go back.
Is this a known bug, or is there a way to restore the creation of the dimension lines?
Thanks in advance
Michele
Posted by Keet at Jan 31, 2026, 11:09:03 AM
Re: ESC key issue
It might help if you mentioned which plugin.
Posted by mikimichele82 at Jan 31, 2026, 6:20:00 PM
Re: ESC key issue
Yes, you are right!
I due a mistake: it was my first time in the forum and Ia pressed “New Thread” instead of “Reply” in a previous conversation.
Anyway thanks for your reply and the plugin I refers to is “3D dimensional lines”.
Thanks
Michele
Posted by Daniels118 at Feb 1, 2026, 6:38:23 AM
Re: ESC key issue
Quoting myself:
I know there are bugs using the plugin with the latest versions of SweetHome3D. I haven't had the time to fix them, so the only chance is to use the native dimension lines, or downgrade SweetHome3D to a previous version (7.0 should work fine).
Keep in mind that native dimension lines can be placed vertically using the edit dialog.
