Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Use all screen realstate in scrolling window manager |
| Print at Oct 20, 2026, 7:38:01 AM | |
| Posted by GreenBackBone at Feb 19, 2026, 7:03:45 PM |
Use all screen realstate in scrolling window managerIm using Arch Linux with Niri scrolling window manager in this manager all windows spawn using half the screen the thing is that when i maximize sweethome3d window the actual usable realstate stays in half is there a way to have it use the full mazimize space? i attach video for visual explanation Video Of My Trouble thank you for your time |
| Posted by GreenBackBone at Mar 12, 2026, 3:33:19 AM |
Re: Use all screen realstate in scrolling window manager no one? :'( |
| Posted by Daniels118 at Mar 12, 2026, 5:05:43 AM |
Re: Use all screen realstate in scrolling window manager The program fails to calculate the real size available, most likely because it fails to recognize the dpi, perhaps on a high dpi display. There is a custom setting which allows to override the default scaling, see this post and experiment different values until you get the expected result: https://www.sweethome3d.com/support/forum/vie...read,5384_offset,10#28822 If it doesn't work at all, you may try to reduce the dpi to a standard value. MS WINDOWS allows to force the dpi to a specific value when a target program is executing (compatibility option), perhaps you can achieve the same on Linux (using some additional software?). |
Current timezone is GMT Oct 20, 2026, 7:38:01 AM |
