Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: how to update new version? |
| Print at Sep 29, 2026, 2:56:39 AM | |
| Posted by balisage at May 1, 2010, 4:21:26 AM |
how to update new version?hi...i found my problem with how to update my sweethome 3d v1.7 with v2.3. should i uninstall the oldest one and install with new or there's another way? could you please help me with this. thanks guys... |
| Posted by Puybaret at May 1, 2010, 10:12:11 AM |
Re: how to update new version? If you installed Sweet Home 3D with Windows installer, simply run the installer of the new version. You won't lose your furniture library and preferences because they are stored in user directories. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by gracyhelen at May 10, 2010, 2:12:01 PM |
Re: how to update new version? hai how to create the 3d house |
| Posted by Ablondal at May 26, 2010, 11:26:52 PM |
Re: how to update new version? When I run the windows installer for V2.4 (to update from 2.3) I get this error: "Delete file failed; code 5 Access is denied" Do I need to uninstall 2.3? and If I do will I keep all my saved files? Thanks. |
| Posted by Puybaret at May 27, 2010, 8:33:10 AM |
Re: how to update new version? You're not obliged to uninstall the previous version of Sweet Home 3D before updating it. The error you mention probably means that the installation program couldn't delete a file or write over it. I suggest you to install Sweet Home 3D 2.4 in an other directory to avoid this problem. In all cases, upgrading won't delete your saved files, and the models and the textures you imported in Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ablondal at May 28, 2010, 12:43:19 AM |
Re: how to update new version? Thanks for the help! Great Program, Thanks to all who worked on it! |
Current timezone is GMT Sep 29, 2026, 2:56:39 AM |
