Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Sweet Home 3D and Macintosh G3, OSX 10.4.11 don't mix!!! |
| Print at Sep 30, 2026, 9:38:34 AM | |
| Posted by rblue at May 22, 2010, 2:11:49 AM |
Sweet Home 3D and Macintosh G3, OSX 10.4.11 don't mix!!! I downloaded the installer package, ran it and indicated that I wanted it loaded to a volume (not the same as where the system lies) where all my third-party applications reside. I have Java 5 update loaded as well. I click on the application and it does launch, it bounces on the dock twice and the menu bar shows Sweet Home 3D - but only that and then....nothing.I ran the console program and this is what it recorded: ===== Friday, May 21, 2010 9:02:20 PM US/Eastern ===== [JavaAppLauncher Error] value for 'JVMVersion' key in 'Java' should be a VM version string (e.g. "1.4.2") [JavaAppLauncher Error] value for 'JVMVersion' key in 'Java' should be a VM version string (e.g. "1.3.1") [JavaAppLauncher Error] CallStaticVoidMethod() threw an exception Exception in thread "main" java.lang.UnsupportedClassVersionError: com/sun/javaws/Main (Unsupported major.minor version 49.0) at java.lang.ClassLoader.defineClass0(Native Method) at java.lang.ClassLoader.defineClass(ClassLoader.java:488) at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:106) at java.net.URLClassLoader.defineClass(URLClassLoader.java:243) at java.net.URLClassLoader.access$100(URLClassLoader.java:51) at java.net.URLClassLoader$1.run(URLClassLoader.java:190) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:183) at java.lang.ClassLoader.loadClass(ClassLoader.java:294) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:288) at java.lang.ClassLoader.loadClass(ClassLoader.java:250) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:190) at apple.launcher.LaunchRunner.loadMainMethod(LaunchRunner.java:55) at apple.launcher.LaunchRunner.run(LaunchRunner.java:84) at apple.launcher.LaunchRunner.callMain(LaunchRunner.java:50) at apple.launcher.JavaApplicationLauncher.launch(JavaApplicationLauncher.java:52) Warning: unrecognized command line flag -foreground Can anyone help? This program looks terrific and I was looking forward to learning and using it... ![]() |
| Posted by Puybaret at May 22, 2010, 10:37:51 AM |
Re: Sweet Home 3D and Macintosh G3, OSX 10.4.11 don't mix!!! I tested Sweet Home 3D 2.4 beta under Mac OS X 10.4 yesterday, and it worked with no problem (it wasn't on a G3 though). From your console message and a request similar to yours, I guess you're running Sweet Home 3D from the Java Web Start link and not from the installer package. Try to run it from the installer version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by rblue at May 25, 2010, 12:03:06 AM |
Re: Sweet Home 3D and Macintosh G3, OSX 10.4.11 don't mix!!! I tried by launching the installer version. Its started as before, this time a color modal window comes up with Sweet Home 3D, then it disappears. And then....nothing, as before.... ![]() |
Current timezone is GMT Sep 30, 2026, 9:38:34 AM |
