Print at Oct 2, 2026, 10:58:19 AM
Posted by homi at Jun 3, 2010, 2:48:01 PM
How terminate the room?
I would terminate (close?) the room. I created room (4 walls, oblong) then I want modify size with mouse, three wall hold together, but last not. How join it?
Posted by hansmex at Jun 3, 2010, 3:22:57 PM
Re: How terminate the room?
Homi:
When nearing the 4th wall, you'll notice that it is highlighted. Double-click on the fourth wall and it will close, giving you a nice closed corner, elastically linked like the other ones.
Posted by homi at Jun 3, 2010, 7:12:53 PM
I'm ass, I' did that many times, but in bad way. Thanks hansmex.
Now, I have room and I want to set dimension:
1) How to set dimension (length), for two collinear walls, for ex. from 9m to 7.50m? If I select one wall I have option to set length (via modify), but if I select two walls, this option disappear?
2) I set dimension, but if I change length of wall via mouse, dimension not change. How to anchor dimension to wall?
Posted by hansmex at Jun 3, 2010, 10:50:46 PM
Homi:
You can rent my services as an SH3D consultant for just a measly US$100 per hour.... plus ticket(s) and expenses, of course.
Now, as an alternative you could start and read the manuals.
Apart from the fun... if you can't change TWO walls at a time, why not change them ONE at a time?? If you start your coordinates at 0,0 then a 10x10 meters room would be VERY EASY to design, even if using the Modify walls option.
Now.. I don't want you to think that I think you are stupid, so, make me proud!!
