Print at Oct 6, 2026, 6:57:25 PM
Posted by alxeng2002 at Jul 1, 2010, 12:33:30 AM
text rotate ?
its possible rotate the text to vertical position ?, I havent found yet some example or plugin...
Thanks...
alxeng2002
Posted by Puybaret at Jul 2, 2010, 10:29:54 AM
Re: text rotate ?
It's not possible at this time.
A feature request has already been submitted about that.
The workaround is to export the plan to SVG and rotate the texts with Inkscape.
Posted by alxeng2002 at Jul 2, 2010, 1:40:00 PM
Re: text rotate ?
I tried this, but how I import svg to sweet ?
Thanks
Posted by Puybaret at Jul 6, 2010, 12:16:26 AM
Re: text rotate ?
You can't import svg files in Sweet Home 3D.
Posted by hansmex at Jul 6, 2010, 8:40:30 AM
Re: text rotate ?
Alxeng:
You could convert the SVG picture into a JPG. Then import the JPG as a texture and stick it to a very flat box. You can rotate the box every way you want.
