Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: optical lenses |
| Print at Oct 5, 2026, 6:28:14 AM | |
| Posted by SirBobolo at Jul 8, 2010, 9:48:39 PM |
optical lenses what do i have to set to get a picture like (fore example) shot with a 16mm camera and a 25mm lens? thanks! |
| Posted by hansmex at Jul 9, 2010, 12:34:52 AM |
Re: optical lenses Sir: If you download and install the plug-ins to Create Advanced Photo, you can choose from 4 different lens settings: Default, Depth of field, Fisheye and Spherical. That's at far as it goes until now. If you need more control over your rendering, you can export your model as an OBJ file and use another program. See this thread . Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by db4tech at Jul 9, 2010, 3:23:46 AM |
Re: optical lenses Hi SirBobolo and Hans, SirBobolo welcome to the Sweet Home forum. ![]() If you are meaning aspect ratios and focal length. Aspect ratio can be chosen, or custom ones entered, in any of the render windows including the create Advanced photo... plug-in the Hans mentioned. Focal length can be selected by right clicking anywhere in the lower right 3D preview (or from the 3D view menu item) and select Modify... in the Modify... window there is the option to enter Visitor field of view (°) the default is 63 which is equivalent to around a 28mm lens. ![]() db4tech |
| Posted by SirBobolo at Jul 9, 2010, 9:45:20 AM |
Re: optical lenses [quote If you need more control over your rendering, you can export your model as an OBJ file and use another program. which programm would you recomend? |
| Posted by SirBobolo at Jul 9, 2010, 9:47:15 AM |
Re: optical lenses in the Modify... window there is the option to enter Visitor field of view (°) the default is 63 which is equivalent to around a 28mm lens. Ist there a table where i can look them all up? |
| Posted by hansmex at Jul 9, 2010, 11:54:25 AM |
Re: optical lenses SirBobolo: Having a lazy day? What about using Google? Blender Art of Illusion Misfit 3D Wikipedia Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 5, 2026, 6:28:14 AM |
