Print at Oct 8, 2026, 4:45:06 AM
Posted by captainkirk at Jul 15, 2010, 3:07:57 AM
Curved Shower (Base & Glass Walls
does anyone know a simple way to model this shower in Sweet Home 3D?
http://www.kinetikhardware.com/en/?page=130
I couldn't find any type of curved object (furniture, etc) that I could use
thanks for help!
Kirk
Posted by db4tech at Jul 15, 2010, 11:51:39 PM
Re: Curved Shower (Base & Glass Walls
Hi Kirk,
Welcome to the Sweet Home forum.
Probably the easiest way would be to model it in a 3D application, such as Art of Illusion, then import the model and build the rest of the bathroom scene from there.
Just built this glass door for you (attached to the end of this message), to help get you started.
If you would like a curved part for the shower base, have a look on the Sweet Home 3D models page, round wall part, I was going to use and adapt this, for the glass door, but it was too thick, so built a door using Art of Illusion instead.
Look forward to seeing your completed bathroom. smile
db4tech
Attachment Curved_glass_door.zip (1362 bytes) (Download count: 2506)
Posted by captainkirk at Jul 18, 2010, 2:56:02 AM
Thanks, hope to try this tomorrow!
cheers, Kirk
Posted by db4tech at Jul 19, 2010, 2:48:32 AM
With the picture you supplied being a computer render, could you (legally) access the actual original shower model? If so, it could be converted into either obj or 3DS format, then it can be imported in to Sweet Home.
db4tech
