Print at Oct 4, 2026, 12:22:29 AM
Posted by bsyap at Aug 11, 2010, 4:52:45 AM
confused   How do i build a SweetHome3D v 2.5 source project?
Hi everyone,
I have downloaded the SweetHome3D v 2.5 source project and try to compile and run it using Eclipse IDE. I have read the README.txt which paste
-Djava.ext.dirs=lib;lib/windows in VM argument.
However, i failed to build the project.
Below is the Exception thrown :
Exception in thread "main" java.lang.UnsatisfiedLinkError: no j3dcore-ogl in java.library.path
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: Could not initialize class javax.media.j3d.VirtualUniverse
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
Any solution on this?
Any developer's guide, article on building a SH3D source project?
Thanks smile
Posted by Puybaret at Aug 11, 2010, 9:42:24 AM
Re: How do i build a SweetHome3D v 2.5 source project?
First, your question isn't How to build but How to run... wink
The UnsatisfiedLinkError you got means the program couldn't find the Java 3D DLL j3dcore-ogl.
Try these other VM arguments:
-Djava.ext.dirs=${workspace_loc:SweetHome3D}/lib;${workspace_loc:SweetHome3D}/lib/windows
or
-Djava.library.path=${workspace_loc:SweetHome3D}/lib/windows
And prefer to run the main method of com.eteks.sweethome3d.SweetHome3D class.
Posted by Puybaret at Aug 11, 2010, 9:50:15 AM
An about a developer's guide, there is this one, but it's in French.
Posted by bsyap at Aug 12, 2010, 3:00:41 AM
Hi Puybaret,
Thanks for the reply and tips, i am coming from a c# background where i build most of my project using MVS2008. I have learned Java language before, build my Java program in very "old-school" way, TextPad wink
Yes, i have followed your instruction and try to run it again, but it failed too.
1)I am using the source project(CVS tar zipped file ) where i downloaded it through http://sweethome3d.cvs.sourceforge.net/viewvc/sweethome3d/SweetHome3D/ , am i getting the correct source project ?
2)Then i try to download another source project from http://sourceforge.net/projects/sweethome3d/files/ and try to run it, i did not received an UnsatisfiedLinkError Exception but i get another new exception so called :
Exception in thread "main" java.lang.UnsatisfiedLinkError: C:\Users\Boon Shyang\workspace\SweetHome3D\lib\windows\j3dcore-ogl.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform
3)I am running the source code in Windows Vista-64bit. In MVS2008, i can run this project in either 32 bit and 64 bit, but can i do the same thing using Eclipse IDE? Or should i go for other IDE such as Netbean? Perhaps, using a Java2C# convert tool?
Any help is greatly appreciated. Thanks smile
Regards
bsyap
Posted by Puybaret at Aug 12, 2010, 9:12:15 AM
As you're able to build the project without errors, you have the correct source wherever it comes from. The only difference is that you can retrieve the current version with CVS whereas the SourceForge.net download section contains only the released versions.
The exception you got suggests that Eclipse has some problems to run Java 3D 32 bits DLLs. I guess it fails because you installed a 64 bits JDK on your computer. If you replace it by a 32 bits environment (including Eclipse one), you'll be able to run Sweet Home 3D in the same environment as the one available for download.
You may also replace the 32 bits DLLs found in the lib/windows subdirectory of the project by their 64 bits version found here. I'll be pleased to know if this second solution works correctly.
Posted by bsyap at Aug 16, 2010, 3:17:24 AM
Hi Puybaret,
I have followed the instruction given above, but still can't run the SweetHome3D program in Eclipse. Maybe I can show you some configuration in my Eclipse,
First, I have download a release version of SweetHome3D project (SweetHome3D-2.5-src.zip ) and i have unzipped it.
Second, I try to import the Project and try to run it. (Run as Java application). I have selected the com.eteks.sweethome3d.SweetHome3D as the main class.
Under Run configurations, the Main Class is com.eteks.sweethome3d.SweetHome3D
and i have paste the -Djava.library.path=${workspace_loc:SweetHome3D}\lib\windows
under VM arguments.
When i click run, an Error Message box pop-up which shows that
Could not find the main class:
Shayng\Downloads\SweetHOme3D-2.5-src\lib\windos.Program will exit.
Any idea about this?
Thanks
Regards
bsyap
Posted by bsyap at Aug 16, 2010, 3:26:23 AM
Hi Puybaret,
Just a short update, when i try another VM argument which is -Djava.ext.dirs=${workspace_loc:SweetHome3D}/lib;${workspace_loc:SweetHome3D}/lib/windows,
An Error Message box pop-up which shows that
Shayng\Downloads\SweetHOme3D-2.5-src\lib;C:\Users\Boon.Program will exit.
Posted by Puybaret at Aug 16, 2010, 9:25:39 AM
This is really some basic modifications for an Eclipse programer. sad
Add some quotes around the paths if required:
-Djava.library.path="${workspace_loc:SweetHome3D}\lib\window"
or:
-Djava.ext.dirs="${workspace_loc:SweetHome3D}/lib";"${workspace_loc:SweetHome3D}/lib/windows"
Posted by bsyap at Aug 17, 2010, 3:15:36 AM
Hi Puybaret,
Thanks for the reply and suggestion, sorry for giving you so much trouble. sad
Yes, i have read your reply and you have place another thread post which has the same problem as me do for running a source project with Eclipse[Here ].I have read that post also. smile
Finally i can run the source project in my computer. laughing
I am using the
as the vm argument and it works fine.
But when i try with another vm argument
the same old problem still occurred which the program can't find the native library in java.library.path. Any idea? confused
Regards
bsyap
Posted by Puybaret at Aug 17, 2010, 8:08:18 AM
Maybe with a 's' at the end it would look like an existing subdirectory of the project and even to a very well known brand: wink
-Djava.library.path="${workspace_loc:SweetHome3D}\lib\windows"
Posted by bsyap at Aug 17, 2010, 10:42:59 AM
applause   Re: How do i build a SweetHome3D v 2.5 source project?
Hi Puybaret,
You are correct! smile
Seems like there is no other running error after all. I can close the case.
Cheers. laughing
Regards
bsyap
Posted by Puybaret at Aug 17, 2010, 11:27:12 AM
And why are you trying to run Sweet Home 3D from Eclipse?
Any project in mind?
Posted by bsyap at Aug 18, 2010, 3:00:33 AM
Hi Puybaret,
I get to know Sweet Home 3D from Google when i typed in "free interior design software". You really doing a good job! It is a very cool interior design software.smileBesides that, the most exciting part is the plug-in feature provided.biggrin
As all the developers do, always start reading from the README.txt before you proceed. It's good to have Eclipse as a debugging and running tool.
Since i am quite new in Sweet Home 3D project(just started to compile and test the application tongue ), maybe i will just start to be a tester and try to report some bug. I can also provide some help/answer to other users in the forum.
Cheers.
Posted by Puybaret at Aug 18, 2010, 8:10:20 AM
Thank you for the information and feel free to contribute! smile
