Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: User lamp control |
| Print at Sep 28, 2026, 8:56:24 AM |
| Posted by db4tech at Aug 28, 2010, 9:06:16 PM |
Re: User lamp control Ah! my young padawan, you learn quickly! Yes I noticed the wall. Oh! Just spotted (on my render) that we have a regression bug, plus I can replicate it every time. Where is the sconce model from, is it archive3d.net? db4tech |
| Posted by whippetsleek at Aug 28, 2010, 9:12:52 PM |
Re: User lamp control It is my own design, and I'll try attaching it in this post. I started fresh from the orignal lamp scone, because the mesh was just to weird, so I made my own version of it in Sketch up. The mesh is much smoother, but I have to admit the idea was a friend of mine who made the original in Blender as a 3ds file. Anyone can use this if they like, and let me know if anyone does not have Sketch up, and I'll convert it into 3ds for them. ---------------------------------------- ---------------------------------------- ![]() |
| Posted by db4tech at Aug 28, 2010, 9:28:27 PM |
Re: User lamp control Found out that if I remove the 'Plate, glasses and cutlery' models the render completes without problem. PS: Sketchup I don't use. So 3DS convert you must! Thank you, db4tech |
| Posted by whippetsleek at Aug 28, 2010, 9:45:33 PM |
Re: User lamp control Here you go... Also put in a zipped obj file if anyone finds that easier to work with. And you should try Sketch up, it is a cute little program. Of course it is not as good as AOI but it is easier to use, and change textures with. And Master Yoda Tech you not be if the ways of Sketch you do not learn... ![]() And BTW, Thank you for attaching the glass top. I am trying to correct the file with your glass top for the table now. I'll post a picture when, if, I get it done. The table base is a dae file, and I'm having trouble with converting the meshes in Obj form. Some of the faces just disappear. I'm guessing that is due to the differences in assigning 3d coordinates between the two file types, but I don't really know. But I do like the color of the glass top, so hopefully it will work soon... lol ---------------------------------------- ---------------------------------------- ---------------------------------------- ![]() |
| Posted by whippetsleek at Sep 3, 2010, 7:45:31 PM |
Re: User lamp control I was told of a problem with the 3ds file for the scone. It won't let me edit the download, so I would just like to let people here know that the above 3ds file is no good. I'm not sure what happened, but I will try to fix the 3ds file, and repost it. The Object file works great for me, and if you experience a problem with it, please let me know. Thanks! Or if Puybaret would be kind enough to just delete the download or attachment? ---------------------------------------- ![]() |
Current timezone is GMT Sep 28, 2026, 8:56:24 AM |
