Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Resize entire plan |
| Print at Oct 3, 2026, 7:25:27 PM | |
| Posted by edice at Aug 22, 2010, 3:46:51 AM |
Resize entire plan Hi, I built my sweethome plan by tracing my house plans. Now, after some measuring of the house, I release the original scale was not correct (or the plans weren't correct), and the whole house is a little bit too big. Is there a way I can resize the entire house by a percentage? thanks Paul |
| Posted by maker at Aug 22, 2010, 7:14:44 PM |
Re: Resize entire plan As far as I can see, the only way is to export as OBJ. Open in Wings3d or similar program. Scale it there. Import as furniture. But maybe someone can come up with a better idea Good luck ;-) |
| Posted by starrunner at Sep 15, 2010, 12:27:11 PM |
Re: Resize entire plan You could use this new plugin: Advanced plan editing It has the resize action, you are searching for. After installing you just need to select all items in the plan ([Ctrl]+[A]) and open the resize dialog in Edit->Resize. |
| Posted by Paps72 at Sep 25, 2010, 6:52:54 PM |
Re: Resize entire plan Why don`t Import as a new Furniture, and make it there bigger, or smaller??? That is possible, when you exmport the Project (or maybe splitted in parts) as .OBJ (Must all parts been marked, or that, what you want to resize/copy). Best way, I make it, with the "Copy as new Furniture" Plug in. But before, check the size of the walls! Maybe walls to slim?! |
Current timezone is GMT Oct 3, 2026, 7:25:27 PM |
