Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Everything red |
| Print at Oct 2, 2026, 8:47:52 AM | |
| Posted by Schattenmann at Aug 29, 2010, 4:50:55 PM |
Everything redJust woke up this morning and jumped on the computer to keep working on a project. This program is really great, it's the first time I've ever used any software of this sort and its ease of use and intuitiveness has made the work really exciting. But, I have run on a problem that has dashed my spirits on the rocks. I opened my project, and everything is red. Doors are big red cubes, the wall textures are red, the floor, windows, everything! The only thing that is not red is a chair rail moulding I imported, and even though it is red it has lost its form, instead of moulding it is just a rectangle shape. What could have caused this?! I have two versions of this room. I opened the other file and it is perfectly normal, even though it uses the same objects, textures, etc. (I created the room, saved the file, then saved later changes as a different file name two have two versions). Is there any way to recover the room? Has anyone else encountered this issue? I searched the FAQ and browsed this forum, but I didn't see anything similar. |
| Posted by Schattenmann at Aug 29, 2010, 4:57:50 PM |
Re: Everything red I forgot to include my version information. I'm running Version 2.6 Java version 1.6.0_21 on Windows XP Professional version 2002 service pack 3 |
| Posted by whippetsleek at Aug 29, 2010, 7:50:26 PM |
Re: Everything red I'm not an expert, and others will likely give you a much better answer, but I had a similar problem when I accidently used a texture file that was too big, and my graphics card couldn't handle all the calculations so I had to increase the graphics RAM and crop down the size of the texture. Try updating your graphics driver if you know the graphics card you have. ---------------------------------------- ![]() |
| Posted by Schattenmann at Aug 29, 2010, 8:28:43 PM |
Re: Everything red I'm using the latest driver for my card. |
| Posted by Puybaret at Aug 29, 2010, 8:38:55 PM |
Re: Everything red Did you save, quit Sweet Home 3D, and then open your file? No error message? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Schattenmann at Aug 29, 2010, 9:16:38 PM |
Re: Everything red I'm trying to think of variables. I saved, but I did not close Sweet Home. I hit the hibernate button on my keyboard, and the computer blue-screened. Now that I remember the bluescreen, that may have caused the problem, but how? The damaged project had already been saved and was open when the bluescreen occurred. The second project is not damaged and was not open when the bluescreen occurred. |
| Posted by whippetsleek at Aug 29, 2010, 9:26:42 PM |
Re: Everything red Try shutting the computer down completely, or if you have a ram cleaner, run it. Sometimes errors will stay resident in the ram and keep giving you headaches. If you know your way around DOS, you can try a RAM dump and see what errors are there, or look at the error TXT that Windows usually sends to the TEMP folder. And I'm not sure, but I think Sweet Home has it's own console that will tell you error messages, but I think that would be an Puybaret answer. I've never looked into Java console messages. ---------------------------------------- ![]() |
| Posted by Puybaret at Aug 30, 2010, 10:17:44 PM |
Re: Everything red A BSOD (Blue Screen of the Death) doesn't help for sure! But it should be annoying only if it happens while you save a document. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Schattenmann at Aug 30, 2010, 10:58:47 PM |
Re: Everything red Well, I shut down completely last night, but the project is still all red. I've moved on using the second version of the project as a base to re-create the lost project, but Puybaret if there are any error logs I can forward to you let me know which ones and where to get them. |
Current timezone is GMT Oct 2, 2026, 8:47:52 AM |
