Sweet Home 3D Forum » List all forums » » Forum: Forum in other languages » » » Thread: Problemas en vista 3D |
| Print at Sep 26, 2026, 10:24:32 AM | |
| Posted by leonelpedron at Aug 31, 2010, 3:28:42 PM |
Problemas en vista 3D Instale una version anterior creo la 2.1 y luego el paquete de plugins, y tengo este problema en como se ve en 3d. Desintale todo y puse la ultima vesion 2.6, pero sigo con el mismo problema, en otra pc instale directamente la 2.6 y se ve perfecto. este es el problema: ![]() |
| Posted by hansmex at Aug 31, 2010, 3:58:33 PM |
Re: Problemas en vista 3D TRANSLATION I installed an earlier version, I think v2.1, and then the package of plug-ins, and (now) I have this problem with how 3D looks. I uninstalled everything and then installed v2.6, but I still have the same problem. On another PC I directly installed v2.6 and it looks perfect. This is the problem: <image with problem> ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Aug 31, 2010, 5:43:57 PM |
Re: Problemas en vista 3D Intenta DirectX solución: FAQ. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by leonelpedron at Sep 1, 2010, 1:09:37 AM |
Re: Problemas en vista 3D Le cargue la actualizacion del driver de video, sin resultados. Lo pude solucionar agregando el archivo SweetHome3D.l4j.ini Muchas Gracias !!!. Traduccion: I load the video driver update, to no avail. I could fix this by adding the file SweetHome3D.l4j.ini Thank you very much!. |
Current timezone is GMT Sep 26, 2026, 10:24:32 AM |
