Print at Oct 7, 2026, 8:30:41 PM
Posted by jmd at Sep 16, 2010, 5:38:48 PM
Dimensions of the Open door in 3D view
Hello from France
I'm talking about the "open door" you can see open in the 3d view.
It seems to be 1.8 meter wide open and I cannot resize the lenth of the door.
any idea ?
many thanks
Posted by maker at Sep 16, 2010, 7:51:22 PM
Re: Dimensions of the Open door in 3D view
Dbl-click on the door (in Plan View). Make changes as wished... Doesn't that work for you?
You cannot make changes in the 3d view (Just in case you're trying that ;-)
Posted by jmd at Sep 17, 2010, 12:49:01 PM
Thanks, but it does not work on my computer
I just foud the solution :
- create an open door but do not slide it on a wall, let it in the middle of the room !
- then resize it (it works)
- then slide it on the wall with the arrows of the keyboard, NOT with the mouse !
I'm done.
Have a nice day.
Posted by Puybaret at Sep 18, 2010, 9:57:48 AM
You could also use the shift key (or disable magnetism in the preferences) when you drop the door on the wall.
See also this message.
Posted by jmd at Sep 19, 2010, 8:17:32 AM
OK, strange behavior of the open door
now we have 2 solutions
and I've discovered magnetism in Sweethome3D
thanks
